MAF Mass Air Flow Help!
Old Jan 16, 2006 | 03:40 PM
MB_E430's Avatar
2007 C230 Sport
Sorry for double posting (Tech Talk) just want to get this fixed fast especially from some W210 owners with experience.
Got the following codes this weekend:
P0170 Fuel Trim Malfunction (Bank 1) ) check vaccum leaks first or
faulty MAF (mass air flow) sensor
P0173 Fuel Trim Malfunction (Bank 2) )
Leading to believe it's a MAF problem. I have been reading threads all day but still have a few questions:
Will the MAF sensor cause rough idle?
Where is it located?
What kind of labor is needed to replace it?
Can it be fixed or should it be replaced?
What happens if you don't replace the unit?
Who has the best price on a new unit?
Old Jan 16, 2006 | 03:43 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Sorry for "double-answering" :
# 1 - YES
# 2 - TOP REAR OF ENGINE - NEAR FIREWALL
#3 - 10-15 MINUTES
# 4 - REPLACED
# 5 - HAVE YOU EVER SEEN THE FRAM OIL COMMERCIAL.."PAY ME NOW...
# 6 - EBAY
U R WELCOME
Old Jan 16, 2006 | 04:41 PM
fatchance's Avatar
E430
Yes, it can.
It is attached to the air filter housing. Sits inline between air filter housing and intake pipe. Unplug the connector and you should have it in your hand.
I'd say it's more in the front 1/3 of the passenger side of the motor rather than near the firewall.
5 mins. If you can undo a couple of clips, and one band clamp with a screw driver.
Yes, it's a wear item.
Bad mileage, lumpy idle, check engine lights
I ordered one last week at drivewire.com for 184 (plus tx since I'm in Ca) I did not find anything less.. about 200 shipped to me.
Good luck,
-travis
Old Jan 17, 2006 | 04:36 PM
MB_E430's Avatar
2007 C230 Sport
Thanks to for all the advice it's greatly appreciated.
I also did a parts search and found:
http://www.drivewire.com/mercedespar...massmeter.html Bosch $184 free shipping
Drivewire had the best price.
Old Jan 17, 2006 | 05:21 PM
Air Marshall Eldritch's Avatar
John Deere
speedmbparts.com has it for $161. Make sure you get the one for the V8 engine, not the V6. Part number ends in 113 instead of 112.
I also see them on ebay for the same price if you get lucky (nobody else bids on it).
Old Jan 17, 2006 | 05:35 PM
fatchance's Avatar
E430
Thanks for the link. I'll shop there next time!
-travis
Old Mar 20, 2007 | 01:13 PM
RickyE430's Avatar
2001 E430 Sport
Good Morning!
Does anyone know if the proceedure is as easy on an 01 E430 ? The Dealership wants 700 to replace. Thanks
Old Mar 20, 2007 | 01:56 PM
fatchance's Avatar
E430
Should be the same procedure as outlined above. Same engine.
Don't pay 700.00! Use the links above to purchase the Bosch part and save yourself a bunch of $$$.
If you have a Check Engine light on, go to Autozone and they'll clear it for free after you install the MAF.
-travis
Old Mar 20, 2007 | 02:08 PM
Nellie B's Avatar
2001 E430 Designo
Originally Posted by RickyE430
Good Morning!
No, No, No!
Far too excessive cost for a trivial procedure - as noted above a couple of clips and one clamp.
I could buy the part, fly to Phoenix, do the job, charge you less (only a little tho ...) and come home with some cash.
- Nellie
Old Mar 20, 2007 | 03:22 PM
RickyE430's Avatar
2001 E430 Sport
Originally Posted by Nellie B
No, No, No!
- Nellie
Nicely put ! Thanks for the info, I owe you a beer
Old Mar 20, 2007 | 03:41 PM
edischy's Avatar
I had the same codes on my 96 E320. Rough idle, fluctuating 300-400 rpm, hesitation on acceleration. I tried to go the cheap way and bought an air flow sensor on line ($120) and installed it myself. It is very easy to do. Takes about 15 minutes. It has one electrical plug and a couple of hose clamps and is located between the air filter and the engine air intake on the left side of the engine compartment of my inline 6 cylinder.
However this did not solve the problem. I ended up taking it to the dealer who first replaced an O2 sensor ($400). The check engine light came on again and still ran rough after I left the dealer. When I took it back they replaced the mass air flow sensor with a MB part and that fixed the problem (for another $400+).
Beware too that even if you replace the sensor yourself with a genuine MB part, the adaptation data in the computer may need to be reset by someone who has the equipment and know how. The folks who sell these cheap air flow sensors don't tell you that.
Hope this helps. Good luck.
Old Mar 20, 2007 | 06:47 PM
OldNate's Avatar
1998 E320
I bought an OEM maf insert on ebay for $90+$10 shipping, worked like a charm This is what I bought, but from a different seller.
http://cgi.ebay.com/ebaymotors/MASS-...91364217QQrdZ1
Old Mar 21, 2007 | 09:46 AM
John Deere
$700 is just laughable. That dealer is insane, but I bet a number of people get rooked on a regular basis because they don't research it.
Old Mar 21, 2007 | 12:00 PM
RickyE430's Avatar
2001 E430 Sport
I almost did. I just paid orver 500 to fix an A/C leak. The next morning the check Engine light was on. Took it in and they said the MAF was bad. Wanted 750.00 to fix but knocked a few bucks off because I have been a loyal customer.....unreal
Old Mar 21, 2007 | 12:29 PM
fju2112's Avatar
2002 E320 4matic 92K (bought 12/20/06). 2000 E430 4matic (RIP 12/9/06) :(
how would one know the MAF needs to be replaced, short of rough idle and the engine codes listed in the first post?
Old Mar 21, 2007 | 11:26 PM
lxl_Jeffro_lxl's Avatar
1987 E300 TD
I got a Solus Handheld CPU in my schools auto shop that clears the codes....if you drop by with your car during my class I can read / clear codes for you ( If you live in or near Valencia, CA) But hey, just take your car down to autozone or something....it's worth to see what codes your car has thrown
Old Mar 22, 2007 | 07:28 PM
Tommy_s4's Avatar
ML320, Looking for my S4
i'm looking for a 3in maf for my car, any ideas?
Old Mar 22, 2007 | 08:03 PM
Benzs's Avatar
E320 1996
I bought this one on e-bay;
http://cgi.ebay.ca/ws/eBayISAPI.dll?...7346&rd=1&rd=1
So far works perfect
I called the dealer they wanted $499.00 Plus Tax
