Blown Shocks???
Old Dec 29, 2006 | 03:01 PM
VIP ONE's Avatar
WALD out w210 and w203 daily grinder
Blown Shocks???
I recently ran over a pothole. It bent my rim a lil bit (front driver side) but no leaks or anything and everytime i let go the steering wheel, it still goes straight. So Im assuming the alignment is still fine. Unfortunately, the (front driver side) was lowered .5-1 inch lower than its usual height for some reason. My question is do you guys think i blown my shocks or i messed up my alignment???
Old Dec 30, 2006 | 12:52 AM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
If I were you, I would check the spring perch above the pads to make sure its not bent.
Old Jan 4, 2007 | 07:49 PM
VIP ONE's Avatar
what if its bent.... do you know any place where i could take my car?
Old Jan 4, 2007 | 08:18 PM
Richard / E320's Avatar
2001 E320
I would sure think that if you bent a wheel, the alignment would need to be checked.
Old Jan 5, 2007 | 08:09 PM
If you live near me then I could recommend a great Indy shop, but personally Id take it to the dealer otherwise. Unless you know of another very thorough shop in your area. Slightly related note...The same thing happened to my friend in his civic over the course of a few months. It turned out that he had nailed so many potholes that his subframe was actually seperating. I know that hondas are not built to the same quality as Mercs are, but you get the idea. A sudden drop in ride height in one corner is a serious matter.
Old Jan 5, 2007 | 09:01 PM
VIP ONE's Avatar
I took my car to firestone this afternoon and had a computerized wheel alignment. It turned out that my front tires werent aligned and my camber was way off because of the stupid pothole. So they recommend me to get camber kits. I also had them checked my f and r suspension, whoa theyre fine and no rust or anything at all They charged me $300 for everything, these covered four wheel computerized alignment, front camber kits and labor. I guess thats not bad at all.
Old Jan 6, 2007 | 08:30 PM
Thats good news then. So was the height corrected with the adjustment as well?
Old Jan 7, 2007 | 12:54 AM
VIP ONE's Avatar
It was corrected and the height in the front kinda even, not perfect though because they saying the manufacture thing wont allow them... ohh well! but overall.... im pretty satisfied
