Has MB changed recommendation from MB1 0w-40 to 5w-40 for w210 2001?
Old May 5, 2007 | 01:31 PM
takaseem's Avatar
2001 E320, 2003 CLK320
Exclamation Has MB changed recommendation from MB1 0w-40 to 5w-40 for w210 2001?
Hello folks,
I bought my 1rst MB (2001 E320) in Jan 07. It has done about 5K miles since last oil change. I would like to continue to change at 5K intervals. I have searched these and other forums and most everyone says to use Mobil1 0W-40. Mobile website suggests the same for this car. Only few here and there on the forums recommend 5W-40. One person stated that his dealer used 5W-40 and told him they used to use 0W-40 but changed to 5W-40 due to a new bulletin they received from MB.
I just called a dealer near me and they said the same thing. They now use 5W-40 for this car. They said if I want 0W-40 they can put it, but they recommend 5W-40.
Has anyone heard of this new bulletin change from MB? What is the difference between the 2 grades of oil? What grade should I use?
I appreciate your input.
Old May 5, 2007 | 02:51 PM
takaseem's Avatar
More info,
I just got call back from Service Advisor at the dealership. He checked with others, they don't know why MB changed their recommendation of oil from Mobile1 0W40 to 5W-40, but he read me the e-mail they received which was dated Jul 20, 2006. Since that date they have switched to 5W-40 on all cars with model year 1998 or newer.
I also called another dealer, and he confirmed. He said they used 0W-40 on AMG only, and the rest they use 5W-40 for 1998 or later models.
Is there much difference between them? Would there be much differece in the gas mileage? I currently do about 20-21, but most of my driving is in city.
Old May 7, 2007 | 06:56 PM
zx11blade's Avatar
2001 E320, 2008 E63 AMG
The Mobil website lists MOBIL 1 OW-40 Unsurpassed performance synthetic motor oil particularly recommended for high performance engines. And the MOBIL SYNT S 5W-40 Synthetic extra high performance engine oil suited to petrol and diesel cars. Well suited to multi-valved, turbo-charged engines and direct injection systems.
Old May 7, 2007 | 09:04 PM
uberwgn's Avatar
e300d
Mobil 1 ESP Formula M 5W-40
The new oil addressed by the service bulletin is dealer-only. It's the low-SAPS oil mandatory for the new diesels...it's not Delvac 1 or equivalent. This is a brand-new product prepared for MBz. i don't think it is certified against any other OE specs. Again, dealer-only.
Old May 7, 2007 | 09:24 PM
takaseem's Avatar
Are you saying this is a different oil than the 5w-40 available at most stores (wal-mart, autozone ...etc, which is set for turbo diesel engines), and is only available at dealer shops?
If so, I am not sure what marketing strategy Mobile1 has, but losing the market with other oil change shops makes it hard to understand why "dealer only"?
Old May 7, 2007 | 11:26 PM
takaseem's Avatar
Thumbs up
Thanks uberwgn!
I think I found the answer; those are 2 different oils and are described here:
Mobil 1 Turbo Diesel Truck 5W-40 is here http://www.mobil.com/USA-English/Lub...ruck_5W-40.asp
Mobil 1 ESP Formula M 5W-40 is here http://www.mobil.com/USA-English/Lub...la_M_5W-40.asp
I just hope the new one will be available at stores, and won't be limited to dealerships.
Thanks again.
Old May 8, 2007 | 07:37 AM
uberwgn's Avatar
e300d
Thanks uberwgn!
Thanks again.
Again, they are not the same oil. And, again, it's dealer-only for the Formula M product.
The API oils have a high level of additization and that ultimately would poison the exhaust after-treatment devices of the newest cars. That's why the new product is labeled low-SAPS indicating it will work with the BLUETEC vehicles.
In general, the API specs and the Euro oil specs are mutually exclusive. Proper MBz oils carry a 229.xx designation.
MBz seeks to have only one bulk oil and this is the direction they've taken. This newest oil is NOT required in earlier cars whether gas or diesel.
Old May 8, 2007 | 08:27 AM
uberwgn's Avatar
e300d
MBz Oil TSB sez:
"Mobil 1 ESP Formula M 5W-40 is formulated to meet the latest Mercedes-Benz engine oil specification MB 229.51. This new formulation is designed to offer high levels of performance for Mercedes-Benz diesel and gasoline engines as detailed in the Dealer Technical Bulletin P-B-18.00/17d dated April 13, 2006."
Mobil 1 ESP Formula M 5W-40 replaces Mobil 1 OW-40, and will be provided to dealers based on deployment through ExxonMobil distributor network.
To prepare for the transition you must draw down Mobil 1 0W-40 bulk tanks to a minimum 20% level in preparation for the new product."
Old May 8, 2007 | 08:28 AM
uberwgn's Avatar
e300d
Mobil sez:
Product Description
Mobil 1 ESP Formula M 5W-40 is an advanced performance synthetic engine oil designed to provide exceptional cleaning power, wear protection and overall performance. Mobil 1 ESP Formula M 5W-40 is engineered to help prolong the life and maintain the efficiency of Car Emission Reduction Systems in both diesel and gasoline powered automobiles that require an oil that is approved against Daimler Chrysler's MB 229.51 specification.
Features and Benefits
Mobil 1 ESP Formula M 5W-40 is made with a proprietary blend of high performance components formulated to be fully compatible with the latest Diesel Particulate Filters (DPF's) and Gasoline Catalytic Converters (CAT's). Mobil 1 ESP Formula M 5W-40 has been designed to deliver outstanding overall performance and protection.
Old May 8, 2007 | 08:42 AM
uberwgn's Avatar
e300d
Viscosity @ 100C:
  • Mobil Formula M 5W40 13.35cSt
  • Mobil Delvac 1 5W40 (and equivs) 14.8cSt
  • M1 0W40 14.3cSt
  • Mobil 1 ESP Formula 5W-30 (Europe only) 12.1cSt
This new oil is a "thin" 5W40. The equivalent product in Europe is sold as a 5W30. The Euro 5W30 oils meets 229.51, VAG's 507.00 and the other basic ACEA ratings.
Attached Thumbnails Has MB changed recommendation from MB1 0w-40 to 5w-40 for w210 2001?-3093mobil_1_507.jpg
Old May 14, 2007 | 12:09 PM
Aqib's Avatar
Which oil to be used for E320 1996
Mobil sez:
Hi
Can any one tell me the recommended oil to be used for 1996 E320 with 130,000 Km on it? I live in Montreal, Canada where the general concept is to use different kind of oils in winter and summer. I am more interested to use some synthetic oil but I read a lot of problems occuring while switiching from conventional to synthetic oil. Can any one help me figure out this problem. Thanks
Old May 14, 2007 | 03:09 PM
uberwgn's Avatar
e300d
Modern cars utilize modern all season/all climate oils. MBz would suggest 0W40 year round. We can purchase this oil quite easily in the USA, don't know about Ca. You'd also have access to Elf or Motul, both of which will address the MBz quality standards.
Nobody here will know if you are going to suffer leaks when making the change from petro-based oil to syn oils.
Old May 15, 2007 | 12:49 AM
4XFORE's Avatar
1998 E320 / 1992 LandCruiser / Project Car E30, 91, 318I
I buy my oil from wallmart. 0w-40
Old May 16, 2007 | 10:55 AM
JeffreyP's Avatar
Mobil sez:
That's a little confusing as I thought the 229.51 (the 1 at the end) is an indicator of diesel engine.
My thought is that it shouldn't make that much difference as 0w40 has been proven over the years.
Old May 16, 2007 | 12:43 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
I am not sure when the dealers here started recommending the Mobil 5W40 oil but I was told about 1 year ago. Like the one post said, their storage tanks had to get down to a 20% level before they were allowed to switch. I was told by my primary dealer that although the TSB was dated April 2006, they did not change until after June (when I bought my car). I had asked to make sure I was adding the correct viscosity, and they confirmed that mine had 0W40 in it when I bought it.
Old May 16, 2007 | 02:30 PM
uberwgn's Avatar
e300d
That's incorrect, Jeff. 299.51 is both a diesel auto and gas auto standard.
229.51 indicates low-SAPS suitable for use in diesels with specialized exhaust after-treatment. It will also be applied to the gas engines.
I don't know what kind of car you have and won't comment on its oil requirement.
There's no reason folks can't continue using M1 0W40 (unless you're operating an '07 diesel auto) since it's widely available and meets the required spec(s).
Old May 16, 2007 | 03:20 PM
JeffreyP's Avatar
Hi uberwgn
Here's the direct quote from
http://www.whnet.com/4x4/oil.html
" MB sheet 229.51 approved oils; low ash long life
Mercedes pioneered this new spec for passenger cars with diesel engines with EURO 4 or Bluetec exhaust particle filters and longer service life than the 229.31 oils. The spec was introduced in 2005. Change intervals increased to 20,000 kilometers. Based on ACEA A3 B4 and C3"
However, I believe you as the earlier quote say it works for both diesel and gasoline engine. By the way, I have the 98 E-320 and has been using Mobil1 0w40. As I said earlier, It shouldn't make that much of a difference as 0w40 is still an approved 229.5.
What's strange is that 229.5 (0w40) can go up to 30000km while 229.51 (5w40) goes to 20000km so is 229.51 (5w40) really a better oil?
Regards,
JeffreyP
Old May 16, 2007 | 03:33 PM
uberwgn's Avatar
e300d
Hi uberwgn
Regards,
JeffreyP
Again, 229.XX is the standard for both gas and diesel autos.
Using any of the 229.xx oils in your 1998 gas car is fine and "approved". M1 0W40 certainly is a well-suited choice.
The 229.51 spec represents the latest in engine lube oil technology. Is it "better"? Dunno. The jury is still out and we'll have to wait and see what wear levels look like.
Old May 16, 2007 | 09:30 PM
Y2KE320's Avatar
08 E550
Yes, this is true for MB and for Porsche. 0w40 to 5w40. You should use synthetic such as MOBIL 1
Hello folks,
Old May 17, 2007 | 11:25 AM
takaseem's Avatar
Y2KE320,
See uberwgn's replies above, 5w-40 is an formula M type (not the same as teh 5w-40 for diesel available at stores) and is dealer only. This is not available in stores for those who want to change their own oil (unless you buy from dealer, in which case probably it is not worth changing it yourself).
I think this only leaves the 0w-40 for those who want to use Mobil 1.
Old May 17, 2007 | 04:32 PM
fdte320's Avatar
So, for my 2000 E320, Mobil 1 0W-40 or 5W-40????
Old May 17, 2007 | 06:29 PM
uberwgn's Avatar
e300d
M1 0W40 or the dealer-only Formula M 5W40
Old May 21, 2007 | 10:20 PM
wilmac49's Avatar
Smile 229.51 oils
If you are so inclined Amsoil has European car formula in 5W-40 that is marked 229.31, 229.51 Mercades Benz which is what I indend to use in my 07 SLK 350 as Amsoil is all I have used for years. Just FYI not bad mouthing Mobil 1 as that is what I used before Amsoil.
Old Jun 20, 2007 | 07:32 AM
mbnj's Avatar
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
On my '01 320 wagon (dealer services), do I have to find out whether the dealership used 0 or 5 W40 in their last oil change before I know whether I can add (not even change, just add when low) a quart? This seems crazy that a dealer would start putting an oil type in your car that that the customer can't purchase to rectify a simple "low oil" condition?
Old Jun 20, 2007 | 07:40 AM
uberwgn's Avatar
e300d
I'd go ahead and add a little M1 0W40 which you'll find at Wally's or Autozone. That will be the most similar assuming the dealer is using the oil they're supposed to.
