Mass air flow sensor & check engine light
Good job on doing it yourself. Its good to save money!
Jeff
the purpose of completing an OBD II drive cycle is to force the vehicle to run its onboard diagnostics. Some form of a drive cycle needs to be performed after DTCs have been erased from the PCM’s memory or after the battery has been disconnected. Running through a vehicle’s complete drive cycle will “set” the readiness monitors so that future faults can be detected (and potentially to pass inspection). Drive cycles vary depending on the vehicle and the monitor that needs to be re-set. Whenever possible, follow the drive trace prescribed for the specific vehicle/monitor in question. Some vehicle-specific drive cycles can be found in the vehicle’s Owner’s Manual.
The following “universal” drive cycle can be used as a guide to assist with re-setting monitors when a vehicle specific drive cycle cannot be located. This generic OBDII drive cycle begins with a cold start (coolant temperature below 122 degrees F and the coolant and air temperature sensors within 11 degrees of one another). This condition can be achieved by allowing the vehicle to “sit” overnight, and then by beginning the drive cycle the next day. Most drive cycles will be difficult to follow exactly under normal driving conditions, so the driver should exercise caution, road safety, and courtesy to others.
* Start the engine. Idle the engine in drive for two and a half minutes with the A/C and rear defroster on.
* Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle.
* Hold at a steady speed of 55 mph for three minutes.
* Decelerate (coast down) to 20 mph without braking or depressing the clutch.
* Accelerate back to 55 to 60 mph at ¾ throttle.
* Hold at a steady speed of 55 to 60 mph for five minutes.
* Decelerate (coast down) to a stop without braking.
get the i/m read at autozone for free it will tell you if the o2 sensors are in a ready state,same with the cats,etc.if not you are wasting time going to the smog test till they are ready,they have nothing to do with the cleared light from the maf r/r.they are emissions related items.
"GOT CODES?"
p.s. next time save yourself a possible big repair bill,don't drive around a long time with a cel on,a bad maf changes the fuel curve and can result in frying your o2 sensors,sh*t runs down hill!And find a good indie shop,if your not going to do your own repairs,the dealer will kill your wallet.
post the job,we can tell you how to do it.
ohlord
"GOT CODES?"
I would report the dealer to the BBB. I would also stop by and ask to see the dealer's general manager to ask him why he was trying to steal your money. That is an outrageous overcharged for labor/parts. I want to see the dealer make money however, that is theft by deception. The maf cost them 200 dollars and 5 mins labor to replace.
ohlord
"GOT CODES?"
as to the diy,go to benzworld.org w210 forum diy section,the cleaning and r/r are written up quite nicely,pics and all.
And get the code reader at harbor freight or get them read at pep boys or kraggens etc. and post the codes before you do the maf.May as well confirm what the codes are pointing to before doing it and finding out the dealer did not know sh*t..........which is often the case.
