oem cd changer won't play CD-Rs???
what did you do when you disassembled it? you must've done some tweaks.. i'd love to have my changer play cdr's..
I had a normal CD stuck in there. I took the outer cover off, and snapped the trays back into position. Then reassembled. Mag works fine now, and it plays CDrs without a problem (for the past year). Maybe try a different brand of CD-rs. I use the white faced memorex.
mine is an alpine, from 1997 the ones without the fiber optic connection. It sometimes plays cd-r's and sometimes won't it just a matter of luck. I haven't been able to get it to play any lately. I have an Ipod that I use in conjunction with the tape player though.
I would say that mine doesn't "fully" support CD-R's. It might be the brand of the CD-R you're using too.
If I wanted to play CD-R's that bad I would replace it with a newer alpine with mp3 support.
Cheers.
At least my 99 and the pioneer in the mgb.
formats. if you encounter playback issues with homebrewed recordings,
try varying the burn speed...as well as the intensity of the laser.
In my opinion Nero is the best available in CD/DVD Replication.
This will definitely work.
Thanks a lot.
Fred
I've noticed this over the years also.
The Blaupunkt unit with 10 CD Changer that came with my car sometimes played CD-R's and other times wouldn't. Never an issue with Retail Purchased CD's.
This is due to the older units not being designed to play CD-R's.
Differant lead in points, Manufactors & burn speed will make a difference.
Use a top quality brand CD (not the 800Mb varients, good luck in finding them now) and a slower than listed burn speed.
Good luck
J
it wont play cd-r's unless they are in perfect condition and are SONY branded
it seems to be luck as well
no, no stock mb plays MP3 cds
