Cleaning the wood?
Old Jan 29, 2008 | 10:15 PM
Tweel's Avatar
1998 E320 3.2 V6
Cleaning the wood?
what do you guys do to clean the wood panels? because mine could use a clean
i don't think water and a napkin can help...any suggestions?
Old Jan 29, 2008 | 10:50 PM
Bossman123's Avatar
2001 e320 2004 e55
Wax it. I suggest Meguiars NXT. Its synthetic and stands up better than carnuba based waxes that melt of easily in extreme heat. If you accidently get some on the leather or MB tex, it will wipe off without staining.
Old Jan 29, 2008 | 11:19 PM
ohlord's Avatar
Murphy's
oil soap,mixed as directed,dry and protect with any good wax.
ohlord
Old Jan 30, 2008 | 06:09 PM
yoram611's Avatar
E320 2003 silver color
hi ,
use PLEDGE for furniture waxing and cleaning.
Old Jan 30, 2008 | 09:29 PM
kdude87's Avatar
2000 e320 4matic
does pledge really work?
Old Jan 31, 2008 | 11:26 AM
ghaffar23's Avatar
'08 CL600 with 152k km; '01 E430 4Matic with 433k km; '17 Porsche Cayenne with 130k km
From what I understand, Pledge doesn't work well with the wood in the car. There's that clearcoat, and it's a bit different from the household variety. Correct me if I'm wrong. I use the PlasticX, and it hides the scratches very well, and protects it.
Old Jan 31, 2008 | 12:03 PM
tirona's Avatar
1997 s320, 1997 e320
by plastx you mean meguiar's plastx, the same one we are using on the headlight lenses? i would have to give that a try. i have been using pledge til now.
Old Feb 4, 2008 | 05:42 PM
yoram611's Avatar
I have used pledge on my car and the wood looks like new.
after you spray a little on a piece of cloth you spread it on the wood and let it dry for a few minutes , then you buff it well with a dry soft cloth till you get a high glose .
Old Feb 4, 2008 | 07:05 PM
uberwgn's Avatar
e300d
http://www.benzworld.org/forums/deta...wood-trim.html
Old Feb 4, 2008 | 07:21 PM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
I use Griot's Interior Cleaner
Mercedes wood is protected by an acrylic plastic cover. An oil based wood cleaner will produce an oily plastic surface.
Cheers
Old Feb 9, 2008 | 12:18 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
If the wood is scratched, it can actually be buffed with an orbital like the exterior paint. Use a fine compound first and evaluate from there. There is a fair amout of clear over the wood. After that, follow up with the previusly mentioned NXT wax, buffing it off with a microfiber cloth. Once it is nice and smooth, you can clean with a damp, not wet, just damp microfiber. That's how I keep mine clean. Nick
