Water Spill on Consul - Trans Stuck in 1st
Preface: I have searched forum for solution with no luck.
Problem: Spilled a cup of soda all over the center consul 10days ago.
Traction control/ABS/Gauges/Multible Defect Alerts and Failures along with "take it shop service warning" etc....
Limped home in 1st gear having first to overide the Park lockup to get it into gear. Upon arriving home I turn the heat to max and let run for 6hrs in driveway to dry out. Living in wet/cold Oregon I am not sure that get's it done but I headed out of town that night and have to leave is sit.
Go out of town for a week and return to find all the error/service messages are no longer an issue (I guess the soda dried out) but, Tranny still stuck in 1st and will not shift from drive back passed nuetral unless I turn off the engine. It does shift into all gears after re-start but will not shift past nuetral into reverse or park unless engine is shut off.
I reset the factory defaults on TCU/ECU by turning key to on and stepping on trottle for 15secs, etc.... still stuck in 1st.
I am assuming the Trans Electric shift/control unit is still wet or is partially fried so my questions is....can I disasemble and clean will electic/contact spray or is this a part replacement issue? As well, if replacement is required, what is the likely part, and estimated cost? Finally is the remove and replace a DIY or, will I need the services of a qualified tech.
Thanks for help
PS...Tranny got stuck in first about three weeks ago but resolved after re-start.
AND only the Germans would install components near cup hold that are damaged by moisture and/or spills. It almost as if they destain from having to install cup holder by installing such a small a fragile unit to begin with and, as if say "we teach those glutenous yanks" by causing us great expense and hardship every time they spill more than 3-4drops of liquid in the vacinity.
Thanks for help
Go to
benzworld.org w210 section .Look in the diy section or search trans module repair.Nice write up of the removal and clean up with electronic parts cleaner.Give it a try.Before you do that try the disconnecting the battery neg lead and see if that resets the unit.
Good luck
ohlord![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
if it does not work,new units are on the market and I think about 300 bucks if you r/r yourself.
Good luck
ohlord
1 Post
1997 E320 (black) 1996 E320 (white)
Anyhow, knowing that this was a common problem I decided to check out the shifter on a recently acquired w210 and low and behold found sticky coffee all over the insides! Im sure the link that ohlord provided will be thoroughly helpfull but all I did was disassemble the shifter, cleaned it off with alcohol, and polished of all the contacts. Noted, carefull eBaying can land you the entire shifter for under $150.
Word of warning before someone from Germany sees this! I hear originally they were designed NOT to have cupholders there in the first place. Something integrated by us Americans when they where imported here. *heard this from a ranting European in another forum so I can't confirm.
good stuff - thanks
Don't feel bad
There are only 2 kinds of 210 owners....
Those who have done this.....
And those who will...
You can pick these up at PGA for less than 200US and diy in a couple of hors.
Yes, the cup holder is an american design added in 99.
Luck.
Luck.
There is a small spring loaded door just below the gear indicator lables (Park, R, N, D , -, +) where you can insert an ink pen or other sturdy object.
By pressing down with your pen it will unlock the shift level from Park position so you can select Reverse or Drive, etc....
