shocks, springs, struts?? advice
or could it be springs, or is mb a strut design -
by no means am i a mechanic, nor have i ever owned a md before a month ago
love the car, but don't want to learn how to be a mechanic.
Also, it's quite easy to change the shocks yourself. The first one was a bit tough for me but by the last I felt like a pro.
sorry. i did get lazy and swapped out the rear w/o using a spring compressor
but that is not recommended. it's like shifting a manual transmission car w/o
using the clutch. do-able but not recommended.
I've swapped out the rear springs about 4x and the rear pads about 3x. so I
was pretty familiar with the procedure and made some short cuts. requires
at least two floor jacks for added safety.
to the question: can you use...hook compressor? I don't know for certain.
But bear in mind that the lower spring mounting point is quite large and there
is less tolerance for hook-design units than the pancake design.
yeah, it's a bummer that you may end up needing two diff spring compressor
designs for your task. since I've not done this specific job using the hook
design compressor, I can't speak to its effectiveness
