I think I may have screwed up on wheel/tire setup
My tires are brand new General Exclaim UHP's in 235/40/18 all the way around. Just over the past day or so I ran into the threads about wheel size on a w210 and apparently there is an issue with 9J wheels in the front for the w210? The offset on my wheels is ET38.
I actually had the tires mounted and 3 of the wheels actually mounted on the car before we realized that I only had 3 of the hub centric rings. So I had to order another spacer from Lorinser and it should be here after this weekend.
My question is this....
They had 3 wheels mounted and they also test fitted them, and the guys at the tire shop never said anything about not having enough room in the front as far as clearance is concerned. But also keep in mind that the car was still in the air when I saw 3 of the wheels mounted. I never got to put it on the ground. Could someone visually look at something like that in the air and see if it won't work? Or would you have to have the car on the ground before you can really see how it fits?
I feel like such an idiot because I didn't research thoroughly enough before I bought the wheels. But worst case, I would have to sell the wheels and tires. Gimme your thoughts guys. Thanks!
measure twice cut once
ohlord
What is this infamous bolt? And if it were to hit, where would it make contact? Thanks in advance.
I am confused as to how the whole offset/spacer thing works. What does it mean when you put a 7mm spacer on there and it took the offset to ET31? Is that the measurement on the inside or the outside?
in this example lets say the et is 38 and you put the spacer of 7mm in ,it would reduce the 38 to 31 and push the inner rim further out.if you increased rim width without changing et you can see how it could cause problems when clearance is an issue.8 works with a 31 so if your 9's don't maybe a bigger spacer.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
ohlord
1010tires has that cool et calculator that you enter wheel specs and it shows what the net results will look likeas far as inner rim to suspension and outer rim towards fender
ohlord
Get out the roller and the heat gun and she will be fine.235's on 9's is close
At least when you want to you can throw some 265's on the back.
Have the alignment checked and set if needed,those new tires will love you for it.
How did the roll go?
he's facing west
There are numerous reasons why you should stick to specifications or custom tailor made alloys. First of all, mostly you just dont want to have the hassle - alloys should look good - but they should also fit perfectly and safely. This means at any condition the car could be in at any point in time, fully loaded, in sharp curves and so on. Secondly, going beyond specifications on modern cars, can have several kinds of impacts, such as ABS, ESP and BAS malfunctions or conditions out of normal.
Also, please bear in mind that the ET actually is a quite important specification. Going outside specfications can change the handling of the car significantly, and can also have siginifant impact on hub wear and tear....
So buttomline - stay within specifications and be happy.
Rumpel
