Suspension: control arm, tie rod, ball joint...
I have read many people replace the suspension around 100,000 miles.
They feel the handle is much better after the job.
My control arm bushing is not good now. I am thinking about replacing the suspension, also upgrade to E55 sway bar together to save some labor.
The questions are:
A. what should I replace?
1. control arm bushing bushing, of course.
2. Sway bar, bushing
3. Upper control arm?
4. Lower control arm? expensive! is it necessary?
5. Ball joint?
6. Tie rod, inner?
7. Tie rod end?
8. Sway bar link?
9. ?
B. Is it necessary to replace the rear suspension?
C. I found many brands, Lemfoerder, Meyle, Febi... on different websites. Which company is good to choose?
Thanks in advance for your opinion!
Ben
ohlord
If you want the car to drive like new, then replace it all. If you drive like grandma, then replace what's verifiably bad.
Lemfoerder is my favorite. High quality parts, and OEM for lots of Euro manufacturers.
Get it aligned after replacing these parts.
ohlord
How about the lower control arm? Is it easy to be bad?
Thanks!
It's the bushings that go bad, and all rubber suspension bushings deteriorate in 8-10yrs and 100k miles.
ZDmak.com http://www.zdmakrepairtools.com/wbst...CTMP=1&LowCt=0 has a decent unit
I was solid and easy to use when I replaced the front suspension on my E.
The cheapest Lemforder lower control arm I found is still costy, $185.95!
But's it's only a suggestion. Replacing the arms complete makes the entire job much easier, plug and play. Make sure you install the updated eccentric bolts while you're at it...
1. Lower control arm, comes with the bushing, L/R
2. Ball joint, 2 sets
3. Control arm bolt, 4 sets
4. Upper control arm, L/R
5. Tie rod, inner, 2 sets
6. Tie rod end, L/R
7. Sway bar
8. Sway bar bushing
9. Sway bar link, L/R
Anything else?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=015
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=002
The second one looks identical as ZDmak
I don't know should I try it.
