Central locking and rear headrest switch dont work?
The PSE pneumatic control unit . gets a signal from the ccm (combination control unit)and uses air to operate the things you say stopped acting properly.Back by the battery it is a black box with lines to it,check the fittings,also check the fuses while back there.
ohlordSomeone will post a picture of the unit I can't right now my wife just went out to set up a new real estate listing and is gonna have the Benz all day
you are not the only one who has had to be talked down from the pse bridge
http://www.benzworld.org/forums/w210...their-own.html
don't get parts off ebay
http://w210.pietrzyk.net/electrical_combcont.htm
Call autohausaz.com for a quote.But before you pronounce it dead try all the fixes and if need be, before throwing in the part have a shop with a star diagnostic machine check the ccm to pse system.
http://w210.pietrzyk.net/disassembly_reardoor.htm
find the leak or popped off tube.
ohlord
Is this what I need, the circled one?
check vacuum from source to eliminate that as a problem. but it sounds like it may be linkage, too....at the door. only option is to keep with the disassembly
and check in systematic fashion.
