Garage door opener/ RR-V mirror
Old Dec 16, 2002 | 04:36 PM
ricoh64's Avatar
'99 E 430 , '05 E500
how do you program the rear view mirror to operate the standard genie garge door?
e 430 '99
thanx in advance!!
Old Dec 16, 2002 | 05:55 PM
ryson's Avatar
2014 E350, 2008 C300 Sport
With your key in the first position, I believe you hold down one of the buttons on the rear view mirror for a few seconds until you see the tiny orange light blink a few times... while still holding the button down, then hold your garage opener near the rear view mirror and press the garage door button. Release the garage door button, release the rear view mirror button. That should do it if my memory serves me correctly. If you have a garage opener that rotates the garage codes for security purposes, you'll have to program the car as stated above but then program your garage opener to accept that code you just stored in your car.
Old Dec 17, 2002 | 02:33 AM
ricoh64's Avatar
Thanx, tried procedure and it works great .
Old Dec 17, 2002 | 12:42 PM
btx's Avatar
btx
ryson,
are those the same procedures to program the garage door opener on the vanity mirror of 1996 e320?
Old Dec 17, 2002 | 09:21 PM
Greg_S's Avatar
2008 E550
None of the 3 lights in my 02 ever start to blink. Any ideas?
Greg
Old Dec 17, 2002 | 09:36 PM
USFBulls's Avatar
2019 E53 Cab
Have you tried holding the two outside buttons down together for about 20-30 seconds?
Old Dec 17, 2002 | 09:49 PM
Greg_S's Avatar
2008 E550
USFBulls
That got the lights blinking, but it doesn't seam like the process gets the car toopen the door.
Greg
Old Dec 18, 2002 | 09:20 AM
USFBulls's Avatar
2019 E53 Cab
For the Homelink to work with my garage door opener which has a rolling code - I had to first teach the car, then press the learn button behind the garage door opener and then press the button that you programmed in the car. My garage door opener will blink when it learns the code from the car. After that it should work fine.
Old Dec 18, 2002 | 05:07 PM
ricoh64's Avatar
I agree, this is what ultimately worked for me.
Old Dec 19, 2002 | 12:00 AM
gmacosta's Avatar
96 e320
Angry i've tried too
GReg_s I too have a 96 e-320 and tried all the possible ways. i even got instruction straight from homelink. i heard on pre 96 it just doenst work for rolling codes. if anyone has done it please help me?
Old Dec 19, 2002 | 01:23 PM
Greg_S's Avatar
2008 E550
Angry
I'm of the belief that I can afford one of these cars, just not smart enough to do more than turn the key on. I'm going to the dealer tomorrow for some work and will ask them if they can help. I will post the results.
Greg
Old Jul 7, 2003 | 01:48 AM
tomscia's Avatar
1998 E320 Sedan
To program the visor on my 98 E320 I first pressed the button on the Genie's receiver which is mounted on the ceiling of my garage. I then got down from the ladder and within 30 seconds held down the visor button for about 15 seconds before it began blinking rapidly. I did not even use the Genie transmitter to program the visor; only the Genie garage ceiling mounted receiver.
Old Jul 7, 2003 | 10:05 AM
E-Klasse's Avatar
W205 C300
98 was the first year that homelink could do rolling codes like Genie openers have. I replaced my 96 drivers side visor with the homelink buttons inside with a visor from a 98. The 98 visor works great.
