AC Problems
Rating: Thread Rating: 2 votes, 4.50 average.
Old Oct 13, 2010 | 04:53 PM
  #301
autoevolve's Avatar
E420
Answer to gotboost95
Originally Posted by autoevolve
Normally happy with the way AC works as long as I start in garage the 105 temp outside are no problem just when car sits in heat doesn't catch up....Thanks for the help....Julia
1 28
2 39
3 17
4 13
5 20
6 74
7 14
8 55
As usual the nipple I found was the correct one I'm just a girl who didn't have the grip strength to get adaptor to attach and release the R-134...Added just a little of the special R-134 with lubricant all is well wish I had tried about a month earlier.....need best price on Power steering pump now?
Old Oct 27, 2010 | 06:55 AM
  #302
nerissa22's Avatar
2010 BMW M3 Coupe
Hello..I am woking a 9 to 10 hours siting job in AC...it creates many problems for me...Skins problems are more worried things for me.....It makes my Skin too much dry....I am great suffering from this...Please tell me how i can solve this problem....
Old Dec 27, 2010 | 08:31 AM
  #303
frank bolak's Avatar
1997 e 300 diesel
swamp fox
not exactly a reply, but a question? A/C compressor has no power to it but we have 85 lbs pressure in the system.(charged) suspect pressure switch. location? thanks
Old Jun 12, 2011 | 10:14 PM
  #304
peterp1212's Avatar
1998 E300 TD
Did you ever get an answer to your AC issues? My 98 E300 has the same issues
Originally Posted by kinghais
hi guys i just got a 96 E300 and i have some problems with ac, i tried to read the codes but i can't cause right side screen has bad pixels so i cant read'm.
driver side blows hot air and pass. Cold, when both in LOW temp.
when i turn it on and off i hear loud hissing sound from center vents
Helps please
Did you ever figure it out
Old Jun 12, 2011 | 11:10 PM
  #305
usaims's Avatar
98 e320
I have a multitude of issues with my AC; here are a couple of tips.
CHANGE YOUR FILTER! A clogged filter can cause many issues because the AC computer is not getting proper readings from the components.
A hissing sound can be vacuum element issue. On my car, I have 5 or 6 elements. A bad element can cause issues with your vent. How to check these elements requires a mighty vac tool and going under your dash.
Of course check your freon and check for leaks.
Old Jun 19, 2011 | 08:23 AM
  #306
gmahoney's Avatar
2002 E430 4Matic
Strange a/c problem with my 2002 E430
Hello,
I just purchased the vehicle in the title line, and noticed yesterday that the a/c is blowing warm air out of the outer left vent and left middle vent. The right side vents are icy cold. After running the car for maybe 20 minutes or so, the left vents blow barely "cool" air, but nothing like the right vents. Both vents are blowing the same amount of air volume.
Any ideas what the heck could cause this?????????????????
Old Jun 19, 2011 | 09:28 AM
  #307
usaims's Avatar
98 e320
Originally Posted by gmahoney
Hello,
There are vacuum elements in your AC system. If any of them fail, you will get the kind of issues you have. This requires troubleshooting the vacuum elements with a special tool ($40) which test if your vacuum elements can hold a vacuum. I don't know how passionate you are about fixing things, but that is where I would start.
Old Oct 3, 2011 | 06:01 AM
  #308
Poul W. Joergen's Avatar
ML 500
AC on ML500
I have a MB ML 500 model 2006 and having problem with the Air condition system, MB workshop has just installed newest software four times on the control panel and it still doesn’t work. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
Now they want to change the compressor but the A/C working satisfactory up to the point where the fan inside start to regulate down in speed just before the cabin temperature reach the setting and then is stop, but it sometimes start again if I make it as low as possible i.e. 16<SUP>0</SUP>C.<o:p></o:p>
Old May 30, 2012 | 01:38 PM
  #309
bdenise's Avatar
E320
A/C not working 1997 E320
I have a 1997 E 320...with the RC light on...from this forum I was able to collect the codes..this is what i have:
1 -32
2-34
3-34
4-34
5-31
6-90
7-03
8- 46
Error codes
E 61 226
E 61 232
E 61 234
E 61 235
E 61 459
E 61 423
E 61 241
I would appreciate any help with reading the error codes...
Old Mar 20, 2013 | 11:20 AM
  #310
oklodhi's Avatar
E230 1997
I have 1997 E230. The climate control is giving me problem.
When i turn on the ac, sometimes it gives cold air and sometimes warm air regardless of whether the car is running or standing still.
I checked the refrigerant code 07. it ranges from 05 to 16.
No error codes.
The compressor seems to be engaging.
I went to ac shop who said the refrigerant is at half level at 70 pounds.
What can be the problem?
Old Mar 21, 2013 | 11:15 AM
  #311
oklodhi's Avatar
E230 1997
No error codes.
I visited an independant dealer who says the compressor is faulty and it engages and disengages on its own. The compressor will need to be replaced.
Old Apr 24, 2013 | 08:20 PM
  #312
Dnasty's Avatar
2010 e550 coupe
I am having very faint blower at max and it makes a whine noise it's about 62f today I took the values down.
1. 20
2. 16
3. 38
4. 34
5. 55
6. 44
7. 06
8. 17
Old Apr 28, 2013 | 01:01 PM
  #313
cathybandy's Avatar
1995 e320 Wagon
1995 e320... where is the fan blower motor located. Can't even find the thing to test it. Thank you
Gary
Old Apr 28, 2013 | 01:47 PM
  #314
Dnasty's Avatar
2010 e550 coupe
Gary
Directly under the passenger glove box, you'll see a plastic cover.
Old May 1, 2013 | 12:19 PM
  #315
Sturat's Avatar
2001 E430
2001 E430
How big of a PIA to change the expansion valve?
Old May 2, 2013 | 02:50 PM
  #316
Sturat's Avatar
2001 E430
Originally Posted by Plutoe
On a scale of one to ten, I would say it's a 3. Just make sure you evacuated the system first.
The bigger issue is who told you you need to change the valve and why??!!
A mechanic buddy of mine said it was toast.. The compressor was changed right before I took the car. the ac will work sometimes but not all the time.
We put a set of gauges on the a/c system and that is when he said he felt strongly that the expansion valve was stuck/dirty need a new one.
Old May 16, 2013 | 01:01 PM
  #317
02E55Blue's Avatar
2002 E55 AMG Baby
Smile Help me please!!!!!!
Just bought a 2002 E55 and omg is the amg amazing But the air conditioning is only cold on the passenger side... i had it vacuumed down and refilled. Also, the aux fans don't run when you turn the A/C on but run fine when the car is hot... Thanks So Much for all of the help
1 84
2 78
3 75
4 75
5 78
6 125
7 07
8 75
9 48
10 2.9
11 2.4
12 3.9
20 3.2
21 44
22 00
23 32
24 13.5
40 164
41 91
42 72
43 136
E61 232
E61 233
E61 235
i reset it and drove it not the only thing showing is
E ff
The compressor is coming on just fine the ec light works normally and it takes Freon no problem
It Did not come with a manual :-(
Old May 16, 2013 | 03:26 PM
  #318
02E55Blue's Avatar
2002 E55 AMG Baby
Just drove the car and after reset still no trouble codes but here are the readings
1 91
2 145
3 63
4 55
5 80
6 191
7 20
8 120
9 69
10 5.6
11 2.2
20 21.1
21 42
22 00
23 32
24 13.3
40 164
41 91
42 81
43 136
this is at idle with the A/C on.. on the way to lunch i turned the air on the drivers side from auto to the bottom and the left vent and bottom was colder the passenger side is ice cold!!!!! Thanks for all of your help you are amazing!!!!!
Old Sep 21, 2013 | 11:34 PM
  #319
tbone006's Avatar
E320
Originally Posted by Honey001
How do you check the A/C compressor to see if it is working? The blower blows, the system is showing that it is full of freon, but the compressor doesn't come on. Pressure switch?????????
I have SAME ISSUE ...i rechatged system to max safe level. Blower is full blast .. i can see the AC compressor wheel sitting still.. it will not engage . All wires, fuses are intact. BAD COMPRESSOR or is there a fuse/sensor located on or in between switch & compressor?
Old Sep 21, 2013 | 11:44 PM
  #320
tbone006's Avatar
E320
Swamp Fox -- Replies ???
Frank, I think we may have similar issue...you hear any replies yet??
All my system works except compressor not engaging ...???
Old Sep 24, 2013 | 12:24 PM
  #321
tbone006's Avatar
E320
Do yourself and others a big favor----read the forum stickies---then run the AC actual value tests(follow the procedure) and post the data----thats how to get AC help!!!!
Well i DID look thru all the stickys first, as i do everytime i look for assistance on an issue. I didnt see anything to do with Compressor not engaging, so that is why i posted asking Frank ..as it sounded he had similar issue. I will look at Running Test notes ..but i dont have an ECU Computer or any MB specific test equipment. Sorry to "bother" you with my questions
Old May 20, 2014 | 05:43 PM
  #322
roguewrester's Avatar
1999 E55 AMG
1999 E55 AC problem
Old thread with a lot of useful info that I followed and still having a problem. I replaced my blower motor and regulator 6 months ago or so and the air ran OK for awhile. Now the blower doesn;t come on at all. I ran the codes and this is what I got:
B 1 234
B 1 416
B 1 459
1-80
2-82
3- 127
4- 127
5- 121
6- 179
7- 04
8- 94
After running the codes I added 1 can of 234. I was thinking I had a leak but the it went from 04 to 12 and stayed there over night so I added more 234. Its at 14 now and still not working. I cleared the codes prior to adding the 234 and system is still not working so I am at loss . Will old Charcoal cabin filters cause the system to shut down? And what is the B 1 459 fault code I am getting???
Thanks!
Old May 20, 2014 | 07:01 PM
  #323
1999 E55 AMG
Haven't really thrown any money at the problem other than 2 cans of 234.
Here are my updated numbers.
1- 109
2- 69
3- 94
4- 94
5- 87
6- 145
7- 14
8- 129
Also, I 416, is that something I can fix myself?
Old Jun 14, 2016 | 04:41 PM
  #324
Needleroozer's Avatar
1999 E320, 2001 S430
Quick questions...
1999 E320, EC light is on and won't turn off. Sensor readings and error codes point to bad evap temp sensor and no Freon, confirmed by local garage. Local garage wants a fortune for evap temp sensor so I'm doing that myself. They also reported they were unable to turn the compressor by hand and concluded I need a new one - again for a small fortune (i.e., they're asking almost twice for the part alone what I can get it for at an auto parts store).
So my quick questions are 1) Without Freon in the system can they tell it's a bad compressor just by trying to turn it by hand? 2) What's a fair price to pay for a new compressor, accumulator, and Freon charge? 3) What's the standard hours for compressor/accumulator replacement?
Old Jun 14, 2016 | 06:39 PM
  #325
fabbrisd1's Avatar
A gaggle of MB's
The China Evap sensor is cheap - with shipping $14-$18:
http://www.autohausaz.com/search/pn....bbkaAu7R8P8HAQ
Parts wise - Compressor, Drier, possibly Expansion valve, Oil, O-Rings - you can buy a "kit" package from eBay or Amazon:
http://www.ebay.com/itm/NEW-A-C-COMP...VXDT7T&vxp=mtr
Note - the drier design has been updated - and in addition to the parts above you MUST have a new drier hose:
http://www.autohausaz.com/pn/2108304615
All this is very straight forward for any competent auto air con shop - actual time 2-3 shop hours - many will decide not to bother with the expansion valve unless after they bought everything back it's not cooling well.
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
