AC Problems
Old Jun 30, 2008 | 01:56 PM
  #51
koskesh's Avatar
1997 E320
Also I wouldn't attempt to "by pass" the pressure switch to see if the compressor comes on without being absolutely sure there is refrigerant/lubricant in the system. check the low pressure side, on a running A/C system that should read between 20-40 psi depending on outside temperature.
Old Jul 2, 2008 | 12:12 AM
  #52
jwht's Avatar
AC problems
I have a 1999 e-320 and the AC comes and goes intermitenly. In the summer it will be working fine and then all of a sudden it will turn off. In the winter the heat will be on and all of a sudden the AC will be on. If anyone has ideas please let me know
Old Jul 2, 2008 | 01:14 PM
  #53
BoS7463's Avatar
1997 Mercedes-Benz E420
AC diagnosis
i used the ac diagnosis on benzworld and it said i have a bad evap temp sensor, here are values i got from the CC unit:
1-121
2-32
3-93
4-96
5-94
6-108
7-01
The AC is not blowing out cold air and no error codes, also if that is the case, what is the part number on that sensor?
Thanks in advance to any insight as to whats wrong
Old Jul 2, 2008 | 09:39 PM
  #54
mistertonyn's Avatar
1999 E320 & 2008 S550 Designo
The fan speed on mine would go up and down..
above the 3rd or 4th mark but never shut down completely.
it did it for a few months and now it seems to be OK now.
Look into the A/C blower regulator that you can do yourself if that is the problem...it is posted here on the forum.
Old Jul 3, 2008 | 01:27 PM
  #55
koskesh's Avatar
1997 E320
#7 is the refrigerant pressure on the high side, this tells me the compressor is not coming on. Is your system filled with refrigerant?
Old Jul 3, 2008 | 11:28 PM
  #56
TMAllison's Avatar
09' E320
You've got virtually no ref (#7), ext temp of 121f (#1), interior temp of 32F (#2) and coolant temp of 108f (#6).
I'm thinking the engine wasn't running when you pulled the data?
Old Jul 10, 2008 | 08:23 AM
  #57
MercedesLady's Avatar
Unhappy AC Problems
I have a 99 E300 Turbo diesel. The AC started acting strange - blows cool (not cold) air on the passenger side and blows hot air on the driver's side. The day it started doing this, it was working fine and then after sitting at a red light, it started acting up.
My husband is very handy with cars (has rebuilt some engines on older Mercedes that we have had), but he doesn't have a clue about what's going on with my AC.
Any help will be appreciated - we live in the Atlanta area and AC is a necessity during the summer months!
Thanks,
Mary
Old Jul 10, 2008 | 08:59 AM
  #58
ohlord's Avatar
Run
the onboard diagnostics.
http://www.eclassbenz.com/node/27
post the values1-8 and the error codes.
Most likely low r134a or a stuck duovalve.
Both pretty easy fixes in the short run and even if a small leak it should be easy to locate and repair.
ohlord
post those numbers after running the diagnostics per the instructions.
Old Jul 11, 2008 | 01:43 PM
  #59
Sensor Data
Sensor values:
1 - 78
2 - 87
3 - 67
4 - 53
5 - 134
6 - 166
7 - 09
8 - 100
When I tried to get the trouble codes, the only thing that came up was:
E FF
I went through the instructions several times and that was the only thing that would appear. Even trying to scroll through I'd still only get the E FF.
Also, I was a little off on my initial description of the problem. The passenger's side DOES work fine...it's only the driver's side that is blowing warm air.
Thanks for all your help!
Mary
ohlord
Old Jul 11, 2008 | 01:57 PM
  #60
ohlord's Avatar
Give the
duo valve a firm tap with the handle of a screw driver,just like a drum tap.
that may free it up.Does the a/c stay running or is it shutting down after a few minutes?#5 is the evap sensor and that value is a default temp to prevent freezing of the evaperator if the sensor goes bad.
$37 part at autohausaz.com and takes about an hour to replace.diy duo valve cleaning on benzworld.org w210 diy section. evap temp sensor there also or pm me.
ohlord
evap sensor working properly would be in the range of 34-40f for #5
Old Jul 11, 2008 | 02:39 PM
  #61
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
10:1 it needs a does of refrigerant. My '99 had similar symptoms, and a 12oz can of Dupont r134 did the trick. Hubby can handle the job - plenty of how-to's on the internet. Just watch the pressure. It's fairly slow, taking about 1/2 hour to empty the can in my case.
He can also add an ounce of oil first if desired: same process.
Note that this does not mean you have a leak you need to fix. Studies have shown an average "normal" leakage of about 6% per year, and your car is 10 years old.
Old Jul 11, 2008 | 10:56 PM
  #62
TMAllison's Avatar
09' E320
Obviously not cooling with 5 higher than 8, although #7 refrig doesnt appear low.
The tap on the duo-valve costs nothing.
I might try a quarter can of refrig if that doesnt help and then change the evap sensor.
Old Jul 14, 2008 | 03:15 PM
  #63
koskesh's Avatar
1997 E320
3 and 4 are the evaporator temps. there is two one for passenger and driver side. not sure which is which but by looking at the temps you can tell one side is hotter than the other. I would also say you refrigerant is low.
Old Jul 14, 2008 | 05:12 PM
  #64
ohlord's Avatar
3 and 4 are
left and right heater core temps not evaporator temp.5 is evaporator temp sensor and it is malfunctioning replace it and you will be cool city.
ohlord
Old Jul 15, 2008 | 02:27 AM
  #65
koskesh's Avatar
1997 E320
sorry i was mistaken.
Old Jul 15, 2008 | 06:41 PM
  #66
NOLA911's Avatar
g500, e500
New Guy, A/C Woes!
HEy everyone, I'm the new guy! Got my e320 last night. It has been in the family since it's birth and since my mother was going to sell it, I decided it would make a much more comfy daily driver than my current car.
Anyway, I am having issues... This post is about my A/C unit.First problem: left side is about 30 degrees warmer than right coming from the vents with both sides on low- Auto.
Second problem, there is a mechanical sound to the system that started about 3 weeks ago. It is sort of "surging" but also sounds like wind is leaking through a metal blade (sorry for the lack of a better way to explain it).
Anyway, I did the diagnostic check:
1 - 34
2 - 44
3 - 22
4 - 15
5 - 27
6 - 95
7 - 13
8 - 55
Now, these results are NOTHING like anyone elses that I have seen. When searching for error codes, I found none. Help me diagnose this mess!
As a side bar, the car is shaking pretty rough at idle. Any gas at all and it goes away. It only happens in drive, no problem in neutral. I will start a new thead about that .but wanted to see if they were correlated.
Old Jul 15, 2008 | 07:48 PM
  #67
ohlord's Avatar
12.6degrees
F difference.Both vents and heater cores are running too warm if set on low,and the difference added to the high evaporator sensor temp and the sound you have, indicate low r134a level.You need to have the leak located and repaired and the system charged.Nothing unique about your numbers.Just convert them to Fahrenheit
http://www.wbuf.noaa.gov/tempfc.htm
and enter them into the diagnostic software program.
ohlord
Old Jul 15, 2008 | 07:55 PM
  #68
NOLA911's Avatar
g500, e500
Ok, so engine mounts and AC leak.. Other than that, I am astonished by the ride of this car with 130k miles, even compared to the wife's 2 year old lexus.
How does one go about checking for an AC leak? I guess I should leave that to the pro's. Thanks again Oh Lord.
Old Jul 16, 2008 | 04:31 PM
  #69
Dannbro's Avatar
1999 Mercedes E320
Coolant Leak Problem
Today I just discovered that my 1999 E320 is leaking coolant. Yesterday afternoon, I was working on fixing the AC problem with my car (Hot air only, then cold passenger side and hot driver side, all to no avail, even after cleaning the duovalve). While sitting in my car, I noticed the coolant level message on my display, but I ignored it going to work, planning on dealing with it today. While parking my car at work yesterday, I saw a lot of liquid spilled while I was turning into the parking space. On the way home, I noticed the car temperature rising, and when I got home, the coolant system was steaming. This morning, I poured a little coolant in and drove to school to take my senior picture (only about 2 miles), and before I even made it home, the temp meter was almost hitting the red, so I stopped at a gas station and filled the coolant system with water, just so I could get home without it overheating. When I got home and parked in the driveway, the coolant system started emptying itself, leaking all the water out into my driveway.
So now I'm here, what do you guys think is the problem, and where should I look first? Any help is appreciated. Thanks in advance.
Old Jul 16, 2008 | 06:12 PM
  #70
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Wait until the engine is cool. Fill the system with water and idle the engine. You can start under the hood.
1 - Check the upper radiator hose and hoses to/from the tank. Check the radiator itself. It sounds like it's leaking pretty fast so it may be obvious.
2 - Put the car on jacks. Remove the sound proofing panels (if present) under the engine and examine the underside such as bottom of radiator, lower radiator hose and coolant lines to/from transmission.
Hope this helps some. Good luck.
Old Jul 16, 2008 | 09:35 PM
  #71
Dannbro's Avatar
1999 Mercedes E320
Thanks for the reply, but the problem was solved. I took it to a mechanic, and discovered that the duovalve was not screwed together correctly. I was working on it yesterday, so I guess I didn't put the screws in straight, allowing for an opening in the duovalve, and for the coolant to come out. Luckily for me, my friends dad owned the autoshop I took it to, so the work was done for free (minus the $10 gas money). Thanks again.
Old Jul 17, 2008 | 10:54 AM
  #72
RichardM98's Avatar
It's all part of the learning experience.
BTW, be sure to get 50% antifreeze back in as soon as possible to protect radiator and system. You can get the MB product from www.autohausaz.com . I believe there is a approved Zerex equivalent. Do a search here or benzworld.
Old Jul 17, 2008 | 12:29 PM
  #73
Hirnbeiss's Avatar
And recharge your AC first before going into heavier troubleshooting.
Old Jul 17, 2008 | 03:34 PM
  #74
d2Benz's Avatar
2017 GLE350 4MATIC, 2009 ML350 4matic, 2005 4maticWAGON (sold), A Pre-facelift W210(sold)
hot air on driver's side and cold air on passenger's side, couple with a hiss noise coming from the center vent might be LOW freon....
Good Luck
Old Jul 17, 2008 | 05:34 PM
  #75
ohlord's Avatar
Zerex
GO5.
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
