AC Problems
Rating: Thread Rating: 2 votes, 4.50 average.
Old Apr 28, 2009 | 09:41 PM
  #151
topdeez's Avatar
2012 E350 4matic/97 e320 and 01 ml320
Thank you, I'll try that.
Rock
Old Apr 29, 2009 | 07:29 PM
  #152
johnjzjz's Avatar
E420
NO A/C EC light on wont go off
Ok my EC light is on so - i changed the low pressure switch and using a recharge machine pumped the system totally full to spec and still cant get the EC light to go off or the compressor clutch to come on -- any ideas anyone -- jz
Old Apr 29, 2009 | 07:31 PM
  #153
TMAllison's Avatar
09' E320
You evacuated, then refilled right?
Clear all codes.
Old Apr 29, 2009 | 07:34 PM
  #154
johnjzjz's Avatar
E420
Clear all codes.
yea for sure held vacumn 15 min and than re filled the system to total fill the a snap on machine
the car is a 1997 e 420
Old Apr 29, 2009 | 08:53 PM
  #155
qdessa's Avatar
Check this site... http://www.eclassbenz.com/node/27
Old Apr 29, 2009 | 10:28 PM
  #156
TMAllison's Avatar
09' E320
What AC codes are present?
Old Apr 30, 2009 | 08:38 PM
  #157
aghadden's Avatar
!More on the AC Front
So, the stealership tells me my receiver drier is leaking and I need to replace it, as well as the expansion valve (stating it must not be allowing overpressure to escape as the cause of the problem). And I must have a new hose assembly as the parts have changed and it is required, and top it off with a new temp sensor and high/low switch. Any opinions out there? Can't afford to have the dealership do it, but I may try to tackle it myself.
Old May 4, 2009 | 09:43 PM
  #158
usaims's Avatar
98 e320
AC issue #7 = CLO
In the morning, my AC takes about 15 minutes to kick in once I start my car and once the AC kicks in, it's ice cold. In the afternoon, while my car is sitting under sun (Florida sun), my AC takes longer to kick in.
While I was driving and while it was NOT blowing cold, I put my AC in diagnostic mode, and #7 had 'CLO'. What does that mean? Once the AC kicked in I had numbers like 20 degree symbol and 3.
usaims
Old May 4, 2009 | 10:04 PM
  #159
TMAllison's Avatar
09' E320
Never heard of CLO.
3 would be 3 bars pressure, usually displayed as 03; don't udnerstand '20 degree symbol"....?
What are the error codes currently?
Old May 5, 2009 | 08:45 AM
  #160
usaims's Avatar
98 e320
Never heard of CLO.
When the AC is blowing cold:
1. 76
2. 95
3. 50
5. 42
6 186
7. 19 (degree symbol) 0 [19'0]
8 102
In the mornings, when the AC is not blowing cold, #5 is almost room temp. around 71 and #7 is CLO.
Old May 6, 2009 | 10:04 AM
  #161
usaims's Avatar
98 e320
I was able to get some extra fault diagnosis from the AC control unit. The only other fault was 232 (Refrigerant Pressure Sensor B12). Now to replace that part, do I have to evacuate the freon, replace the sensor, and then refill? Or, just replacing the part?
Also, should I do the receiver/dryer while I'm at it?
Old May 10, 2009 | 08:29 PM
  #162
johnjzjz's Avatar
E420
OK the light went off after we forced the charge to it with out the compressor running BUT the low side pressure is to high and it still blows warm air - i need to know the location of the expansion valve GOING TO REPLACE IT FIRST BEFORE THE COMPRESSOR BECAUSE THE PRESSURES ARE STEADY BUT ONLY THE LOW IS HIGH any one HELP ???????? -- JZ
Old May 11, 2009 | 12:05 PM
  #163
ohlord's Avatar
Stop throwing
parts and gas into it.Have you ran the diagnostics and posted the values and errors,as requested?
You could be full up and not know it.Variable demand compressor systems,fill pressures can be tricky to verify with snop on fill.
Post them when you got them.
Old May 27, 2009 | 06:28 PM
  #164
MG's Avatar
MG
Veteran: Army
1998 E430; 2007 Porsche 911 C4S Cabriolet; 2011 Expedition EL Limited; 2014 E350 Estate
Originally Posted by ohlord
did they show you the crack?
http://www.autohausaz.com/search/pro...AC%20Condenser
I assume that all the r134a is gone with a big leak like that,so no problems in having to capture the r134a.Replace the condenser and the drier,then go to an a/c shop have them flush and pull a vacuum on the system and refill it with the correct amount of r134a and oil(the weight and oil are listed on the top cover of the ecu module passenger side in the engine compartment.
go to benzworld.org w210 section I don't remember a diy but post a shout out for Matt L ,he has done the diy most recently and it has been a bit of time since I had to do a w210 so his memory will be fresher as to tool and nut fittings.alldatadiy.com has most of the factory wis so a subscription to it or a member with a current one can tell you if it contains the procedure.
hope this helps
ohlord
Looks like they covered everything except the condenser. Got any pics of it Ohlord?
Old May 27, 2009 | 09:50 PM
  #165
C280 Sport's Avatar
MB’s of all kinds.
Smell from the AC Vents.
We have a 2002 E320 and when the A/C is on it blows cold but then after a short time she starts to blow a funny smell and stops blowing cold for a about 10 seconds or so. Then she starts blowing cold again. Along with this comes a small scratching sound fromk the vents as well. Any help would be great. Thank you.
Old May 27, 2009 | 11:04 PM
  #166
johnny's E320's Avatar
1998 E320 Sedan
Have you checked to see if the cat is still in the house?
Old May 27, 2009 | 11:19 PM
  #167
C280 Sport's Avatar
MB’s of all kinds.
Yes the cat is right here next to me I have it going in for Service A I will have to get the shop to check it out. Im thinking its low on freeon.
Old May 28, 2009 | 11:02 AM
  #168
01BlackE320's Avatar
01 E320
Everytime I've had that experience, it turned out to be a leaking evaporator core. The oily smell hits you in the face from the vents.
The refrigerant is probably marginally low at this point which is causing the compressor to cycle off. A dealer could troubleshoot. Not cheap though.
Just adding refrigerant and not correcting a leak, will only last a few weeks or months.
Old Jun 4, 2009 | 11:49 AM
  #169
eXpLiCitW210's Avatar
I own a 1999 W210 Mercedes.
Have you replaced your cabin filter? It is located inside the glove box, you'll have to remove the cover. It is placed directly behind your glove box, try that first then go with Black's advice.
Old Jun 4, 2009 | 12:16 PM
  #170
loubapache's Avatar
2003 E320 4Matic Wagon & 1997 E320
Try to turn off the AC, turn on the heat, and blower to MAX for 10 minutes. Then repeat that a few more times before you park your car for the day.
Then try to develop a habit to not use the AC the last 5 minutes of the day driving the car (still use the blower).
The main cause is moisture at the evaporator so the bacteria can thrive. Once you keep it dry then they cannot live (like talking water out of a fish tank ).
Many manufactures (Ford, GM) have electronic solutions for this problem by programing to run the fan after the engine is shutdown.
However, MB is engineered like no other so we have to sacrifice not using the AC for the last a few minutes of the day.
Old Jun 4, 2009 | 08:27 PM
  #171
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Interesting idea. I would also take the suggestion to check the systems for leaks.
Old Jun 4, 2009 | 10:14 PM
  #172
ohlord's Avatar
You the same
guy that posted the same question over on benzworld?
The smeel is mold and mildew, the solution is written,why don't you perform it?
The dealer is going to have a field day with you,Buddy
I wish you well and the same for your soon to be much much much lighter wallet.
A service as in bendover A
oh yeah, remove the rat
Old Jun 4, 2009 | 10:21 PM
  #173
ejsheltra's Avatar
You are a feisty one tonight Oh Lord!!! How is Iowa treating ya? Toronto is cool and we are biting nails watching the Pens have at it with the Wings.
Old Jun 5, 2009 | 02:32 AM
  #174
patrick_y's Avatar
2006 E55 and 2002 E320
Ditto. I do this too, I turn off the AC prior to my destination and I cook inside my very hot black car.
But, the good thing is no obnoxious smell.
Old Jun 10, 2009 | 07:05 PM
  #175
esojmc's Avatar
1999 E320
AC stopped working
Turned on my AC today and noticed that it wasn't cooling. Went home and tested with a gauge and it showed empty. Question - does Mercedes use the same cooling thing that other cars use (R12?)? If so, what brand do you recommend? How much do I need. Hopefully it's nothing more serious and a fill up fixes it.
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
