AC Problems
Rating: Thread Rating: 2 votes, 4.50 average.
Old Jun 11, 2009 | 02:47 AM
  #176
ohlord's Avatar
HAVE
you ran the a/c diagnostics program in your climate control?
Is your ec light on and you can;t turn it off?
Start there. If you are not aware that cars since late 1993 run R134a not R12,you might want to do the above and get more of an idea of what you need to do.
Old Jun 11, 2009 | 06:08 PM
  #177
esojmc's Avatar
1999 E320
ohlord,
Thanks for the reply. Sorry if this is in some faq someplace but how do I run diagnostics on the climate control? I will do more research once I get home. The EC light is not on and I can press it and turn it on and off.
Thanks.
Old Jun 11, 2009 | 08:13 PM
  #178
esojmc's Avatar
1999 E320
OK, here are my sensor and code:
1 - 76
2 - 73
3 - 75
4 - 75
5 - 109
6 - 193
7 - 00
8 - 82
Eb1234
E FF
Does the 7 - 00 indicate that I am low on refrigerant?
Thanks.
Old Jun 13, 2009 | 05:26 AM
  #179
TNT_04's Avatar
mercedes
2000 E320....A hiss sound when turn on the fan AC....
Hi All
My car is 2000 E320 , When I turn on the AC fan at low speed , I hear a hiss sound come from front air blow....What's wrong???.Please help me ......Many Thanks..
Johnny...
Old Jun 13, 2009 | 12:16 PM
  #180
ohlord's Avatar
Most likely cause
low r134a, give it a check by running your onboard climate control diagnostics.
http://www.eclassbenz.com/node/27
post the values 1-8
either that or dirty cabin filters.
Old Jun 13, 2009 | 07:13 PM
  #181
TNT_04's Avatar
mercedes
Thank you very much , I will do all .....You have a nice weeken.....Johnny....
Old Jun 14, 2009 | 02:48 AM
  #182
ohlord's Avatar
I will do that. Our 17 yo girl graduated from high school this afternoon and turns 18 in 10 minutes
Old Jun 23, 2009 | 11:43 AM
  #183
JYO's Avatar
JYO
1999 E 320 (sold), 2015 AUdi S5 (sold) 2005 CLK55 Cab, 2016 Honda Pilot Elite, 2011 Jaguar XF
'99 E320 Slow leak and A/C not working now
2 years ago there was a slow leak in my AC and when recharged it would go about 9-12 months before the EC (economy) light would come on in order to shut compressor off and save it from damage. Dye test couldn't find leak.
2 months ago I had it recharged and today the EC light came back on and no cold air. Just minutes before it came on the AC was blowing very cold.
Any thoughts on where to go from here? Thanks.
Old Jun 23, 2009 | 12:01 PM
  #184
ohlord's Avatar
Fii the system
with r134a and get an electronic sniffer form harborfreight tools, sometimes on special for under 50 bucks.
You will find the leak.
After repair run the onboard diagnostics in the climate control panel
to see if you have anyother issues lurking in the wings.
I have used with warranty and new with warranty compressors if you discover it is the culprit.
Old Jun 25, 2009 | 06:28 PM
  #185
512W210's Avatar
1999 E320
A/C problem
Hi guys,
My A/C in my 99 E320 is acting up. Passenger side of dash is blowing cold but the driver side is blowing much hotter air.
My sensors values are:
1 120
2 116
3 125
4 112
5 150
6 181
7 11
8 127
my codes are:
B 1234 and B 1459
Thanks for any help.
Em
Old Jun 26, 2009 | 08:37 PM
  #186
deno's Avatar
02 E430 4matic 07 E550 4matic
ec button
Does anyone know if there is a need to reset ec button after evac and recharge of ac system, I had to put in a barrowed ac control unit to get the ac working again so I ques there might be a way to reset my own control unit or I might just need a new one.
Old Jun 26, 2009 | 10:03 PM
  #187
NIGHTCAP's Avatar
97 MB E320, 97 Volvo XC70, 87 Volvo 240 DL.
I have the same problem with my '97 E320 and looking for what caused it and how to fix it. Anyone??
Old Jun 26, 2009 | 10:21 PM
  #188
ohlord's Avatar
Run the diagnostics
both of you as stated in the http://www.eclassbenz.com/node/27
don't let it run till operating temp of 180 which I see is what you did.
Sensor 5 evap sensor is throwing a temp that will shut down the ac to protect the compressor. So run the tests just as shown and post the values.
From the 150 value for evap sensor it looks to be the culprit.
Post them when you got them.
Old Jun 27, 2009 | 07:26 AM
  #189
TNT_04's Avatar
mercedes
2000 E320 AC. help.............
Hi All
My is 2000 E320....How do I check freon AC ?.....How much for full freon ?.....Please help me ...many Thanks....JOHNNY...
Old Jun 27, 2009 | 11:49 AM
  #190
TMAllison's Avatar
09' E320
Did you pull error codes using the CCU and then erase them while diagnosing?
Old Jun 27, 2009 | 01:14 PM
  #191
ohlord's Avatar
Try
run the tests just like it tells you.
Post the values and errors.
What are your symptoms?
system working but not cold as you like?Etc.
when did it show the symptoms
Old Jun 27, 2009 | 05:12 PM
  #192
99e320sam's Avatar
'99 E320
99 E320 A/C is acting up. Passenger side blowing cold but the driver side does'nt
My '99 E320 is not blowing cold air on driver side but passenger side is really cold. I have looked around on the web but no real solution.
Has any of our members or anyone for that matter come across this problem and if so any luck in solving the issue?
I have looked at www.eclassbenz.com/node/27 and my reading is somewhat similar to others and it is as follows:-
1. 98
2. 103
3. 82
4. 75
5. 123
6. 186
7. 13
8. 138
following
eb1231
eb1234
eb1459
e ff
However the site does not provide a real soultion to the problem, that is, how to go about fixing it.
I would really appreiciate if anyone can help.
Thank you kindly.
Old Jun 27, 2009 | 06:44 PM
  #193
ohlord's Avatar
The ec light is off
try the test again when the engine is cold and follow the diections to start it run 3 minutes and proceed with the test.
Your coolant temp is 186f so you must have ran the test with the car well warmed up.
Post the results when you have them. And then while in error mode clear the errors by hitting both auto buttons at the same time.
From the posted values you look to be low on 134a you could toss in a can and run the tests again. Also give the duo valve a tap on both sides with the handle of a screw driver. That often frees a stuck duo valve and the different temps on both sides issues.
Run the tests again properly since the evap temp sensor is showing a default temp. Easy diy. if it is.
Old Jun 27, 2009 | 07:25 PM
  #194
99e320sam's Avatar
'99 E320
where is the duo valve located
Thank you kindly for your reply.
I was wondering where I would find the duo valve in my '99 E320.
Also I redid with cold engine, started the car and waited 3-4 minutes and took the reading as follows:-
1. 89
2. 91
3. 80
4. 71
5. 120
6. 118
7. 11
8. 120
and
eb1231
eb1234
eb1459
e ff
Thanks once again
Old Jun 27, 2009 | 07:53 PM
  #195
TMAllison's Avatar
09' E320
The dou valve is on the right side next to the computer box. Two alum silo's.....give em a lil whack.
Prob low on refrig.
Old Jun 27, 2009 | 08:42 PM
  #196
ohlord's Avatar
Does the
ac ever just blow regular temp air(not chilled) like after 10 minutes or so?
Cuz that 120 for the evap sensor is way high. Should be around 38-42f
so you may have other issues besides low r134a. Start with a partial can.
Give the duos a firm drum like thunk up aside the head
and get back to us after you do that and clear the error codes.
Cleaning the duo valves(most times the thunk frees them up)
is a diy posted on www.benzworld.org
w210 diy section so you can see where they are located as described above by our esteemed TMallison he know his stuff
Old Jun 27, 2009 | 08:59 PM
  #197
TNT_04's Avatar
mercedes
Hi
Thanks for reply.....System is COLD... but sometimes I heard the HISS SOUND from the CENTER BLOW at LOW FAN SPEED.....I replaced the CARBIN FILTER....still HEARD the HISS..May be Low FREON , Do you think ?....If yes... Please help me.... How to check FREON on the system ?
Please reply ...many THANKS...Johnny...
Old Jun 27, 2009 | 11:45 PM
  #198
ohlord's Avatar
Low r134a
equals hiss in vents.
RRun the tests post the values
punch them into the software program and then just add a partial can of r134a
since it is running cold it probably is just a bit low.
Low side fill port is up on the drivers side top of the engine on that aluminum tube. See the schrader valve
that is the one you want to use when you put a can in.
You don't need the ones with the fancy valves since the mb system is variable and gauges don't indicate fill.
The only way to get it dead on is pull the charge,evacuate the system and refill with the amount of proper oil and r134a as shown on the decal located on the plate by the ecu located on the passenger side back to the left of the engine.
You are just low so go the easy route. Just add a bit see if the hiss goes away. add a bit more if it does not.
You be the judge
Old Jun 28, 2009 | 03:26 AM
  #199
TNT_04's Avatar
mercedes
Hi
Thank you very much.....I will do it.....
Johnny..
Old Jun 28, 2009 | 11:28 AM
  #200
99e320sam's Avatar
'99 E320
will try and let you know
Thanks guys for your help. I will try all your recommendations and see what works.
Also, 'Oh Lord' it does blow regular temp air(not chilled) like after 10 minutes, if that means anything, let me know.
Thanks once again kindly and I will keep you posted with the results.
Thanks a bunch.
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
