1997 E-420 Suspension
I am feeling more bumps while driving on streets. I think my suspension is getting old.
What you do to make it smooth like it used to be?
Do I need to put new shocks in front and back? I want to keep my car stock.
I just want my suspension to be normal like it used to be so I don’t feel every bump from street.
Any feed back and suggestion will be appreciated.
http://www.mbpartswarehouse.com/part...668+11921+9242
It will cost you about $600-$800 installed depends on the labor local shop charge you !!
Total $400 will bring my ride back to soft and original.
) Anyway, you also have a few other suspension items to check. Check your front swaybar bushings, lower ball joints, and the inner and outer tie rod ends. I know. Sounds expensive. But if your local shop will put 4 shocks on for $25.00 each he'll cut you a good deal on these items too. They arent hard at all for a pro and if done at the same time as the shocks you shouldnt be hurt to bad on labor. BUT take it to your local MB dealership to get it aligned. They do the best job. Trust me. You'll feel a more improved ride if you do these things too.
Jeff
138k miles it is time to get the trans fluid and filter changed(past time)
I have the special dipstick and tips on where to get the other supplies if you diy
ohlord
Right now I will just change the shocks. The Ball joint looks good, I don't see any play in them.
Do you know where are suspension bushings are? I check the parts catalog, but don't find bushings. Please check my car photos and let me know where is bushings???
My car now worth $4500. I don't want to spend $1000 to update the suspension. I just want to put all 4 shocks that I can do with part and material for $400.
I don't know what going on with MB W210 pricing, it is going down so fast. Lots of people in my community now driving W210 E-Class and W220 S-Class.
W210's are now way below $10,000 and W220 are way below $20,000.
http://www.autohausaz.com/search/gro...nsion%20System
ohlord
see the photo of front bushings and confirm that this what you talking about "Bushings"!!
i have mercedes e200 elegance, as for elegance u now its too high from the other models like avantgarde, i need u people feed back tht how can i lower my e 200, just to put the springs or what, bcz the springs it says it ll lower 40mm so dont now how much it will go down from its original height, right shes arround 3.5 inches app up from the tyre .
could ny one help me out thnkz
