Esp, Bas Malfunction
Old Dec 20, 2002 | 01:01 PM
2quik's Avatar
malfunction came on today during rain, dealer said to turn it off and on again, and i did that and the lights went off, anyone have any ideas what triggered this, and should i bring it in to the shop? my local mb dlr said all i havve to do is shut it off and restart, it might be dirt on sensors, is this hokus or ??? anyone suggestion r helpful, thanx in advance guys, by the way its a 2000 E430 Sport, with 28,000 miles
Old Dec 20, 2002 | 01:32 PM
Air Marshall Eldritch's Avatar
John Deere
Mine was caused by a faulty switch somewhere in the ABS -ESP system electrical loop. 3 hrs labor to fix it.
But my warnings atarted up every time I turned on the engine. Yours may be dirty sensors.
I don't believe trouble messages will ever just go away. Something has to be cleaned or replaced else the warnings will haunt you forever.
Old Dec 22, 2002 | 09:37 AM
2quik's Avatar
anyone else
anyone else having a similar problem? my dlr just said after he got it on his comp, said no codes were being read, and to bring it back when it lights up again, anyone have a similar prob?
Old Dec 22, 2002 | 10:18 AM
Randy B's Avatar
**SOLD***2003 E500
Mine Too
Mine was the steering wheel angle sensors that crapped out. Dealer replaced them ,a nd have not had a problem since.
Old Dec 22, 2002 | 10:25 AM
Aletank's Avatar
2003 C180k Avantgarde SE Sport Auto
Mine was a faulty brake sensor, the dealer replaced it charging about £1.50 for the part and a Hours Labour costing about £56 in Total.
I have been told that when the ESP/BAS light is Iluminated the Traction Control is disabled !!
Old Dec 22, 2002 | 10:38 AM
*HW*'s Avatar
E240 2,6 Avantgarde
Maybe it's a problem of electrical contact somewhere (batterie?).
Whenever you disconnect/reconnect the batterie, you will get the ESP/BAS-error. You have to "recalibrate" the brake pedal whilst pushing it down when ignition is turned on (engine not running). You also will have to recalibrate the window lifters and the sun roof (see the manual).
(Hope you could decode my English)
*HW*
Old Dec 22, 2002 | 10:06 PM
phungpho's Avatar
2000 E430 Desert Silver
I had the same problem...
2QUICK,
I had the same problem couple months ago. Good luck.
https://mbworld.org/forums/showthrea...threadid=20507
Old Dec 26, 2002 | 10:20 AM
2quik's Avatar
confused
Ok guys now i need your help on what to do, when i bought the car in to the dealer, the lights for the malfunction were not on, and they said the car DID NOT store any malfunctions, so now what do i do? the light comes on once in a while, the shuts of when the car is reset, any input fellow members?
Old Dec 26, 2002 | 05:23 PM
Mr. Vanos's Avatar
MBWorld Founder
2020 GT R Pro, 2019 GT3 RS, 2018 GT3 Touring
Your best bet is to take the car STRAIGHT into the dealer as soon as the light comes on. Turn on/off is a WORKAROUND, and NOT a fix. The fix will probably involve replacing some bad/dirty sensors by the dealer. Don't accept a workaround for a car under warranty.
Old Dec 26, 2002 | 05:30 PM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
THE FIX IS A NEW CONNECTOR ,AND LENGTHING OF THE HARNESS TO THE BAS CONTROL MODULE,,,AND OF COURSE THES PARTS ARE ON BACK ORDER
Old Dec 26, 2002 | 05:43 PM
2quik's Avatar
DSMIT
Thats a good answer but my problem still remains, whenever i bring them the car at the dlr , the light is off, and they tell me they dont see anything wrong, a few days later it will go off and then when i restart its off, ??? do i just go to them and demand they fix something???
Old Dec 26, 2002 | 05:45 PM
DSMIT's Avatar
THEY ARE FULL OF **** ......
TELL THEM TO CALL MERCEDES TECH LINE ,,IF THEY CANT FIX IT ,,,,
OR BETTER YET BRING IT TO MY DEALER AND I WILL HAVE SOMEONE FIX IT
Old Dec 26, 2002 | 06:06 PM
2quik's Avatar
DSMIT
loooool, i wish i was near u, what is the number for mercedes tech line?
Old Dec 26, 2002 | 06:08 PM
DSMIT's Avatar
CANT GIVE YOU THAT,,,HOWEVER,,,800-222-0100 IS CUSTOMER RELATIONS
Old Dec 26, 2002 | 06:22 PM
2quik's Avatar
DSMIT
Thanx buddy for all ur help
