sparkplugs replacements
Old Sep 7, 2008 | 04:49 AM
roach_juts's Avatar
2000 e430( w210),1979 240D (w123), 1992 300e(w124), 1990 mitsubishi galant VR4
hello
i need to change my sparkplugs, is there any DYI about it?
because when i look at my engine its look complicated, not like my w124 engine, which i do my own change oil & sparkplugs replacement
thanks
Old Sep 7, 2008 | 06:22 AM
ohlord's Avatar
pm me
for the special offset 17mm boot tool.makes wire removal easy and wont harm them.
no anti seize on the plug threads.
ngk 7090 plugs
diy on benzworld.org w210 diy section.
takes about 2 hours as a first timer and you will save over $500
ohlord
Old Sep 10, 2008 | 12:36 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Any thoughts on the Bosch plat plus 2 or plus 4 plugs?
Old Sep 10, 2008 | 12:46 AM
ohlord's Avatar
Do not
use multi tip plugs on m112 or m113 engines,they hate them.Use bosch oem or ngk oe platinum single side electrode plugs,they are good for 100k and work flawlessly.ngk 7090 are $2.89 at any good auto supply.I have the 17mm boot removal tool that way you won't hurt the wires pulling them with those pliers and it makes getting to the plugs a snap.
ohlord
Old Sep 11, 2008 | 12:24 AM
Ben'z's Avatar
E320
I used Bosch platinum +2, for >20,000 miles.
Old Sep 11, 2008 | 01:21 AM
ohlord's Avatar
Good for
youThe spark plug interval on the m112 and m113 is 100k miles.Use the correct plug and you will get another 80k out of them
and save a few bucks while doing so
ohlord
Old Sep 11, 2008 | 04:09 AM
roach_juts's Avatar
thanks for the reply & tips, BIG BIG MONEY SAVER!!!!!
Old Sep 11, 2008 | 12:54 PM
ejsheltra's Avatar
I am at 71K miles and would be interested in the 17mm boot removal tool. What about wires? Also 100k interval? NKG or Bosch part, which is preferred?
Thanks. And thanks for the $ saving tips.
Old Sep 11, 2008 | 04:26 PM
ohlord's Avatar
PM
me.
I prefer the NGK 7090 simply because they are the closest thing to the bosch platins that were from the factory.Work great,last as they should and no misfire issues.The 17mm boot tool makes getting the metal boots off the plug ends a simple leverage move that gently pops them off.When removed this way it does not stress the wire and properly taken care of wires on the coil on plug system the wires can outlast the car.
most tips you need are on benzworld.org w210 diy section.The rest I supply on pm,email or phone support if need be.
ohlord
"GOT CODES?"
