Right rear window won't come back up - 99 E320
Old Sep 29, 2008 | 10:25 AM
esojmc's Avatar
1999 E320
I lowered the right rear window over the weekend and now it won't go back up. It sounds like a window regulator problem. I looked through the procedure to replace the window regulator and I would like to do it myself. The procedure I see says to start with the window in the up position. Mine is stuck down - how do I raise the window again? Also, is this the right part?
http://www.stopshopanddrive.com/prod...regulator.html
Any other helpful hints greatly appreciated.
Thanks.
Old Sep 29, 2008 | 11:45 AM
OceanView's Avatar
W212 & W210
When you open up the panel, you can use your hands and push it up.
Old Sep 29, 2008 | 01:47 PM
ohlord's Avatar
Diy
on benzworld.org w210 section
parts on www.autohausaz.com
video door panel removal
http://w210.pietrzyk.net/disassembly_reardoor.htm
Old Sep 29, 2008 | 02:36 PM
esojmc's Avatar
1999 E320
Thanks for the replies.
ohlord, the link I have in my post has the the regulator for $41 while the one at autohausez is $75. Is there a difference? Should I stick to the cheaper one or go with the more expensive one.
Also, I don't own and have never used a rivet gun. What type (brand/size) should I get? I am guessing rivets come in different sizes. What size rivets should I get? Or should I get the OEM ones from the dealer?
Thanks everyone for putting up with all the questions. It's just that I am a little nervous tackling this.
Old Sep 29, 2008 | 02:58 PM
ohlord's Avatar
harborfreight
tools or sears rivet gun,size in diy,I trust autuohausaz never heard anything about the new link,autohauzaz free shipping and a warranty.
new diy recently posted for $6.95 fix by yachtmaster with pics you might want to check it out.
Old Sep 30, 2008 | 12:12 PM
Air Marshall Eldritch's Avatar
John Deere
I bought the same part from the same site you linked to. I bought the cheaper one, lined it up with the OEM I was replacing, and they were 100% identical. And it has not re-broken since I did that fix about 3 years ago.
I bought my rivet gun at Home Depot, and there were only two sizes of rivets. The smaller size looked about right, and it was. If I can find the box in my garage, I'll post the details here.
The hardest part of the job is drilling out the OEM steel rivets with a cordless 18V drill. The replacement rivets can be aluminum, which is easy to work with.
Print out the DIY pictures mentioned above and have them with you.
Old Oct 4, 2008 | 06:26 PM
esojmc's Avatar
1999 E320
Thanks all for all the suggestions. I found a place in Joliet, IL that will do the regulator replacement for $45. I bought the part from www.stopshopanddrive.com. The regulator arrived quickly and was very reasonably priced ($41 + $7s/h). Drove it over to the shop sat. morning and they replaced it in half an hour. Window works perfectly now.
Old Oct 29, 2008 | 11:36 PM
deadernie's Avatar
96 e320, 91 Eagle Talon, 98 SVT Cobra, 74 MGB-GT, 74 TR6
[/quote]
Where can I find this post and pics? Just bought my car. My right window is up but wont go down. Haven't really looked at it yet but I suspect it's broken and it has been rigged somehow to stay up. Any help would be appreciated.
Old Nov 4, 2008 | 06:57 PM
sct1965's Avatar
2004 E320 4matic
Rivet Size
You need to use 3/16" short or medium rivets. Steel ones will be stronger but harder to compress with some of the smaller rivet guns. I did mine with aluminum rivets because I already had them. A few of the clips on my door panel broke so when I get around to replacing them I might swap out the rivets for steel ones.
Old Nov 4, 2008 | 11:58 PM
ohlord's Avatar
Search window regulator fix
on benzworld.org w210 section YMaster did a nice write up of the econ repair
