A/C Vents inside Center Console???
Old Oct 26, 2008 | 08:20 PM
zsalino's Avatar
E320
Question A/C Vents inside Center Console???
Just purchased 2001 E320 with 40k miles. I have been using this forum usually by searching for my topic and most everything important is already covered somewhere. Thank you.
Somebody must know - why are there a/c vents INSIDE the storage unit (under where the driver would rest his right elbow)??
Old Oct 26, 2008 | 11:16 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
To Keep the contents cold..No More Melted candy
Old Oct 26, 2008 | 11:28 PM
ohlord's Avatar
And
if you want,since it distributes the same temp as the main vents.You can also keep a burger nice and tasty warm,if so inclined.Just close all the dash vents and open up the console one,insert burger and wait
Old Oct 27, 2008 | 02:00 AM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
That is not entirely true... If you forget to close the vents on a cold day with your chocolate inside, you can pray the wrapping is sealed or you'll have chocolate all over
Old Oct 27, 2008 | 06:17 AM
ohlord's Avatar
Thus
the warm burger tip
Old Oct 27, 2008 | 09:28 AM
ETP's Avatar
ETP
98 E320 99 E430 w/mods
DAMN I stuffed the cat in there!!! I thought it was some type of built in pet carrier..
Old Oct 27, 2008 | 10:03 AM
ohlord's Avatar
You
are well over your 8year/80,000 mile fried cat warranty
Old Oct 27, 2008 | 11:45 AM
h0rn3t920's Avatar
97 E420 W210, 95 Volvo 850 Turbo Wagon
I make sure my Ipod is always at sufficient working temperature
Old Oct 27, 2008 | 01:24 PM
zsalino's Avatar
E320
Talking Thanks!
Well... not sure if there is a straight answer in the bunch! Finally stumped the panel - Wow!
This group is great. Honestly I have trouble changing a light bulb but I replaced the antenna tip that I lost an hour after I bought the car going through the car wash after researching it on the board. Thanks again, even if no one knows the real reason for the vents!!!
Old Oct 27, 2008 | 03:01 PM
ohlord's Avatar
Those
are the real anwsers.The first ones,keep things cool on hot days, keep things warm on cool days
Honest.For reals.It's in the owners manual.
it even warns you with a note that says
"the compartment can get very warm due to its confined space.When storing heat sensitive objects in the compartment,close the air outlet while heating the passenger compartment.Also do not obstruct the air outlet."
Old Oct 27, 2008 | 07:31 PM
zsalino's Avatar
E320
Talking WOW!
amazing. That is too funny I thought those were all jokes! OK then - we'll go with it. Thanks again!
Old Oct 28, 2008 | 11:57 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Dont forget the pizza. A whole pie stacked slices will fit. Good for a long drive.
Old Oct 28, 2008 | 01:14 PM
michakaveli's Avatar
E300
Old Oct 28, 2008 | 01:16 PM
ohlord's Avatar
Wrapped
in aluminum foil.A 8 lb. turkey takes just 2 hours.
"Just Set it,and forget it."
Old Oct 28, 2008 | 06:10 PM
ejsheltra's Avatar
or maybe baked stuffed peppers or potatos au graton (hearsay) on high for about an hour.
Old Oct 29, 2008 | 08:49 PM
zsalino's Avatar
E320
Cool OK
now I know it's a put on!
Old Oct 30, 2008 | 08:08 AM
ohlord's Avatar
2,3,4,5,8,
and 12.
Those are all real or potential things attempted.
The others take modification kits from aftermarket suppliers to boost console temperatures beyond stock values.Mercedes warns these modifications to cooking temperatures may void warranty for use of non spec parts.
