E430 oil level rising
Not using any coolant, gearbox oil or pas fluid all levels are spot on correct.
I am suspecting petrol contamination via the injectots weeping with the ignnition switched off.
Any other ideas? the fuel rail has good pressure when engine first switched off and seems the same 1 hour later but left overnight there is no pressure, pump only runs for a couple of seconds as normal and engine satrts and runs fine.
I havent got a test gauge just poked the test nipple with a screwdriver not hi tech in know.
Have posted on a couple uk forums but limited knowledge concerning the larger petrol engines and cant find anything on google etc.
Lynall
Lynall
If two liters of fuel leaked into the cylinders and made their way past the combustion and oil control rings A. either your engines intake would blow up when you started the engine or B. the engine would be so poor on compression that it would not run.Either case you would know.
Do you change the oil yourself?If not you might think about a different shop or start doing it yourself so you can be sure of the amount taken out via the dipstick tube and the amount put back in the filter body.
www.mercedesshop.com
resource section diy articles oil change #2
i change the oil and do all repairs myself, when i changed oil last i stuck in 7 litres exactly and the oil was just 1/4 inch below the max mark.I have the removed oil and will take it to work tonight to get some opinions from my fellow mechs and see what they think.
I was thinking of oil analysis.
I think it has a petroly smell but being a diesel mech and always had diesel cars up until this one i am not sure.
Lynall
Yes using dipstick, always check oil weekly, hence thats how i noticed it going up initially, than dash warning came on.
I have just removed the injectors and the fuel rail, refitted the injectors to the rail and pressurised the rail again, left for a couple of hours and there are drips on one injector and another is damp, this is with a cold motor so guessing worse when hot.
Now going to leave overnight pressurised and see how many drips in the plastic cups in the morning.
Lynall
When you started the engine in the morning even a bit of puddled fuel in the cylinder would set off an engine code.Smell the oil it won't smell like gas.
If you did a proper oil change the capacity of the m113 engine is well more than 7 liters so you failed to get it all removed.Did you use the proper suction method?
Off hand 8liters or about 8.4 quarts so you either left oil in the engine or failed to measure it properly,when you filled it.
Your engine would not be running or starting just fine if you had liters of fuel running out the injectors overnight.
Changed wifes oil in her w203 320 yesterday and to be honest the oil smelt the same as the oil from my car, Spoke to an injector shop today and he has seen this fault many times on rover k series engines, and others but never a merc v8.
He also said dirty or contaminated fuel can cause this.
Injectors being tested as we speak so in about 1 hour i will know 100% hopefully.
Lynall
