bigger brakes..
Old Mar 4, 2009 | 03:48 PM
chaydakis's Avatar
bigger brakes..
Hey All,
I'm looking to get bigger/better brakes for my w210(e430). After reading around here for a while, i found that the c32 amg brakes fit a 210? Is this true? Where can I make this purchase?
Thanks in advance.
Old Mar 4, 2009 | 03:59 PM
ohlord's Avatar
You don't
need them.Just install cryo treated rotors and a performance pad set.You have all the brakes you need to haul down a 3700 lb. car and do it repeatably under severe track use.
If you don't do casual track use,you don't even need the cryo rotors and performance pads.
290mm od compared to a 345mm would require different calipers,work on proportioning,different lines.And you would gain next to nill.And your wallet will lose thickness even quicker.Clean up the calipers,mask them off,get some vht caliper paint that compliments your rims and body color and spend the money saved lowering your Cg properly.
Old Mar 4, 2009 | 05:20 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
I have Installed the Four Piston Brake Calipers from the W203 C32 to a 208/210 with the drilled rotors and the result was better braking ..You will have to use a spacer as the calipers do not clear the rims without a spacer.Try Ebay or the classifieds here
I Would recommend the W210/208 AMG Brakes the front Two piston caliper and the larger AMG rotors work a lot better than the stock NON AMG Brakes
they require larger rims for caliper clearance ..But NO spacers are required
Or
Go with a Set of Brembo/Stop Tech brakes ..Larger rims and spacers are required for caliper clearance
Also do not forget the rear brakes
Old Mar 4, 2009 | 06:28 PM
nsupra's Avatar
can anyone name any good performance pads.
If i were to just upgrade my rotors to cyro's and keep the back ones oem would that be a bad thing or not a problem.
Is it ok to have different pads in the front in the front and different pads in the rear?
Old Mar 4, 2009 | 06:32 PM
ohlord's Avatar
When my wagon call pull down fade free
repeatably 60-0 in 112ft.
He hardly needs big brakes,unless he really wants to spend the money,and needs to scrub off speed for hot lap days at his local track.
Cryo need no slots,display no fade,and last for nearly the end of time
Old Mar 4, 2009 | 11:53 PM
chaydakis's Avatar
thanks ohlord, your input is always appreciated.
Old Mar 4, 2009 | 11:57 PM
chaydakis's Avatar
Or
would you happen to have any pictures?
Old Mar 8, 2009 | 03:43 AM
SpaceCity E 430's Avatar
2011 E350 Sport/ 2000 E430
I put factory W210 AMG brakes on my E430 and boy does that car stop now.
The front rotors are two piece racing style with an aluminum hub. The calipers are not sexy looking like the 211 ones, but they work like mad.
Old Mar 8, 2009 | 01:57 PM
43fatman's Avatar
2001 E430 Sport
I did the same thing.
