need help. humming/moaning sound from under car at highway speed
Anybody have an idea what this might be? Could it be the infamous harmonic balancer problem? I'm going to take the car in to the dealer for an "A" service soon and will ask them to look at this but I wanted to be armed with this groups wisdom before I go in. Any help will be appreciated.
thanks in advance,
Fred
Do not take it to the dealer for an A service.You can easily perform that yourself and clear the fss light.
Or at least if you don't do your own maint. interval work,like simple oil changes,go to a place like the http://www.theworkshopmb.com/
in the bay area or have them come to you with the mobile service.
They charge less than the dealer and are more through and real.
or have them locate the sound and fix it,and then you do the A service.
Plugs been done?
Trans fluid changed yet?
If at 116k miles you are way past due.
MB spec fluid only.
Guess I'm just going to have to take it to the dealer and trust that they won't rip me off...
Fred
Plugs been done?
MB spec fluid only.
Plugs were done at 96K
Trans oil drain and filter done 86K and 96K miles. All done at dealer by PO.
Fred
He mentioned it was not the bearings, as I asked that too, cause the sound would be constant and not dependant on accelerator pedal.
Please keep us updated, as I will too, on what is your vehicles condition. In my case, I work out of my car marketing, so I do not want to take a chance and something major happen. Thanks
Fred
I will see Monday on the MB - Good luck
Rare to have a bearing failure and you are due for the fluid change.
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
is plenty thick enough and will quiet down the problem,if it is even a problem.Which if it came out of the mouth of a service rep,I doubt
"GOT CODES?"
Fred
So are you in the correct forum?
Or do you own a w210 and not list it in your profile?
Any further updates from your findings? I did have the rear diff fluid changed preventative back in 2018 when I bought the car. Though I imagine they didn't use a heavy diff grease but rather than trans fluid as someone mentioned. I hope it IS the exhaust and not the driveline or God forbid, the transmission.
Thanks all!
