Need help naming burnt parts
Old Apr 22, 2009 | 05:45 PM
carnoob's Avatar
1998 E320, 1999 ML320, 1994 SL500
Hi everyone, I have a 1998 E320 that I got from a relative, but it needs work under the hood can anyone help me name these parts i need to replace so i can find it on ebay or craigslist etc. thanks
http://s628.photobucket.com/albums/uu5/hondaeg92/.
Old Apr 22, 2009 | 06:42 PM
TMAllison's Avatar
09' E320
I see an ABS pump, Windsheild washer bottle, headlamp assembly, engine wiring harness, AC receiver drier and whats looks like an AMM/MAF on the opposite side.
There some other stuff other folks will recognise.
Based on what happened, you will also need a new hood latch and it has a alarm (plastic) housing intregrated into it that will be melted too.
It might not be worth fixing.
Old Apr 22, 2009 | 07:06 PM
carnoob's Avatar
i found a wrecked 1997 E320 for sale on craigslist. Would the 97 have the parts that i need?
Old Apr 22, 2009 | 07:08 PM
BoS7463's Avatar
1997 Mercedes-Benz E420
as long as the car wasnt already stripped of parts perhaps
Old Apr 22, 2009 | 07:22 PM
illest's Avatar
w210 AMG or S213
97 will have a different engine.
Old Apr 22, 2009 | 07:31 PM
carnoob's Avatar
i know about the engines(96-97 I6 & 98-02 v6), but will parts that TMAllison mention fit for my 98 E320?
Old Apr 22, 2009 | 10:25 PM
TMAllison's Avatar
09' E320
Theres more that bad than what I mentioned I sure. A good body shop might help identify what.
Go here, find your car 210.065(?) and check part numbers being very carefull to read the footnotes for chassis cutoff dates on BOTh cars. Parts might look identical but be diff electrically.
http://www.detali.ru/cat/oem_mb0.asp?TP=1
Old Apr 24, 2009 | 11:22 AM
ohlord's Avatar
Find another car
that bad of a fire is almost as bad as one that has been submerged in a lagoon.You will be chasing problems from now till eternity.
How many miles on the car?
If low miles you can find the poor unfortunate soul in the opposite mirrored position of a blown engine or trans and pick up that car and swap your good engine and trans into it.
Old Apr 24, 2009 | 07:35 PM
saintz's Avatar
GL450
I would worry about all those burned out wire harnesses (and everything connected to them).
Old Apr 24, 2009 | 08:16 PM
JonMBZ's Avatar
06 C55, 09 E350
I would just buy a new one
Old Apr 24, 2009 | 10:36 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
saintz is right on. There could be multiple shorts throughout your electrical grid. You could end up replacing stuff that does not even look bad n the outside but the electronics could be fried. Part it out or find one as Oh Lord suggests and have a merger. good luck with your endeavor.
