w210 engine serial number.
Old Jun 3, 2009 | 09:03 AM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
I am going to be changing the motor mounts on a friends w210 (99 E430). I am trying to order them, but need engine serial number. Thoughts?
Old Jun 3, 2009 | 12:19 PM
ncd20's Avatar
2001 E320 Avant turbo diesel
Phone friend and ask him to open driver side door and consult the sticker!!
surely parts like that have not changed over years any how ..
Old Jun 3, 2009 | 12:22 PM
ohlord's Avatar
try
http://www.autohausaz.com/search/pro.../Motor%20Mount
And then look at the last set of letter and numbers of the vin tag located on the dash or behind the licence plate and buried around several other places on mercedes.
Old Jun 3, 2009 | 04:16 PM
unlukky's Avatar
When ordering motor mounts they are specifically asking for ranges of 'engine' serial number. I can get all that info from the door tag. I realize where the VIN is. I just wasnt sure it had the info for the engine there too?
Old Jun 3, 2009 | 04:22 PM
unlukky's Avatar
Im an idiot. I did RE-look, it only wants the chassis number. Easy. Thanks guys.
Old Jun 3, 2009 | 04:30 PM
loubapache's Avatar
2003 E320 4Matic Wagon & 1997 E320
You can get the engine number from the following sources:
1) On the engine itself (stamped on the back of the engine)
2) A data card that comes with the car.
3) From a VIN decoder like the Russian MB site below. You put in the VIN, it wil generate the same data card mentioned in 2).
http://old.mbclub.ru/mb/vin/?lng=eng
If it is not the original engine, then 1) is the only reliable method.
What you can read directly (other than on the engine) is the chassis number, not the engine number.
Old Jun 3, 2009 | 08:32 PM
ohlord's Avatar
That's
why I pointed him to the chassis serial number on autohausaz.com.
The engines stayed the same,Mid year mounts changed with the chassis numbers. Always the last several numbers of the vin.'
He figgered it out
now does he have the diy on www.benzworld.org w210 diy section?
And that if you are doing the engine mounts might as well order and install new trans mount.http://www.autohausaz.com/search/pro...ission%20Mount
ohlord
"GOT CODES?"
Old Jun 3, 2009 | 08:48 PM
loubapache's Avatar
So all he needed is the chassis number, not the engine serial number.
Old Jun 3, 2009 | 08:54 PM
ohlord's Avatar
That's
why the old saying "The devil is in the details"
Old Jun 4, 2009 | 10:55 AM
99BENZe320's Avatar
1999 e320
where did you order the motor mounts from. ive been looking but cant find them
Old Jun 4, 2009 | 09:56 PM
ohlord's Avatar
In the engine parts section
on autohausaz.com for your year and model,
