My Benz won't start
Start there.
10amps overnight,key out,use the charging post under the hood.
not restart. It will turn the starter just fine but not start. If you let it cool down for a while it will crank okay...Is this an oxygen sensor problem?
www.benzworld.org
w210 diy
crankshaft position sensor
sold for about 60 bucks on www.autohausaz.com
other diy on www.peachparts.com resource section diy articles
I have a 2000 E320 with over 205,000 miles in southern California. Car recently started hesitating and dying at stops. Now engine cranks, but won't start (it previously started if I let it sit overnight).
Codes shown are P010 (MAF-Mass Air Flow Sensor),*
P0306, P0305. P0304, P0300 (misfires),
P0110 (IAT-Intake Air Temp Sensor) and*
P0700 (Transmission).
Since earlier I was able to start using ether starting fluid, I replaced fuel filter. Ran fine for over 1,000 miles, then problem worsened.
I cleaned MAF (Thanks for DIY.) It started, ran better w/o hesitation about 10 min, then died again. (2nd ride home on tow truck.)
Suggestions appreciated (Crankshaft Position Sensor?)
Old Grey Eagle (7-17-2013)*
Codes I listed are total codes in the computer. I just bought the OBD2 CReaderV and have not yet reset any codes.
I have no idea how long codes have been in system. Check engine light just came on recently.
It sounds like it's about to start! I hear everything it just wont fully turn
I tried stepping on the gas a little and still. What do you guys think is wrong? Should I add more gas?
