1999 e320 transmission problems
It needs to be scanned for other MB specific codes (PO 700 is an OBDII generic coce) and have the adaptation values read by a good MB tech.
You can not clear trans codes (nor see them for that matter) with a OBDII scanner.
Have you spilled liquid into the shift module console?
Or left the sun roof open in the rain?
Check for fluid leak around the o ring electrical connection pass side of the transmission. Replace diy is on benzworld.org w210 diy section.
Whom serviced the trans?
I have the 17mm boot removal tool for when you replace the fried plugs.
Lastly when something is wrong and you know it, why push the engine to maximum and abuse it even more?
I never understand why people do that
the car has another rev limiter other than top speed and it is set so you can't over rev the engine in park or neutral, I always wonder why Mercedes needed it. However when I read post of members with something seriously wrong pushing the car to 60 in limp mode,I need wonder no more.
lol obviously it didnt work and i ended up with 12 fried spark plugs i replaced the plugs and the car still runs rough i think i just need a mercedes specific scanner do you know what scanner works best and isnt to expensive? you seem like you know alot about mercedes and i highly appreciate all the help
A code reader will only tell you the code #. Only a Star coder can read & remove the code. I would suggest a star coder to read the problem exactly,then go from there. If you change the fluid, replace the conductor plate as well since its inside the trans pan. its cheaper than replacing a trans later on. Good Luck.
Some of these members here really give good advice. I know I'm thankful.
My wife spilled coke in my transmission, and had to go get it serviced. Had the car for almost 12 years, never had the transmission fluid cleaned. Cost me about 850 bucks.
Now 6 months later, my mechanic is telling me that I have a transmission plug leak. They are estimating it will cost 4 to 5 hundred. I can drive the car, but shifting is delayed. I am taking it to the shop as soon as I can. Right now, the car is just sitting. They tell me this is a common occurrence with E-320s.
He admitted it was an easy fix. He said he wanted to charge 95 bucks for the hour it would take him to replace it. He said the part would cost him 35, and the other amount for a transmission flush would cost 350. He says that he thinks oil has gotten into my transmission that is why he recommends a transmission flush, but admits it is not necessary just to change the plug.
The car drives just fine with transmission fluid, but leaks transmission fluid pretty bad. He ran the codes on the car. Paid him $65 for him to tell me the computer in the transmission is fine.
I got to find out where this plastic plug is on my vehicle. Maybe I can replace it myself. I used to be a mechanic in the Marines over 2.5 decades ago.
Is there a manual I can buy that will assist me in this endeavor?
Thanks again Plutoe for your sage advice.
Now another issue came up on the car, the taillight keeps burning out. I replaced the whole taillight assembly once before about a year ago for $150. Apparently, this happens a lot to 1999 E-320s. Does anyone else have the same problem?
-Sean
