central locking & key fob remote issues
The IR doesn't seem to work. At all. Windows won't go up nor down when I press and hold either button on the key fob while pointing the IR trasmitter at the front door handle. Interestingly, the little square on the door handle where I think the IR receiver is supposed to be is opaque. Is this IR functionality an option? The manual states plainly that the car comes with this functionality....
Second thing... when I lock the car, it does nothing to indicate it's locking. The doors lock, but the lights don't flash, nor is there any sound. When I unlock the car, the turn signals all flash once. Owner's manual says the turning signlas should flash three times when locking... I get nothing. Is this a setting, or a malfunction?
Thanks...
So, MBZ created a perpetual energy source for the RF signal huh? Wow. If only they could scale it up to power their cars...
Thanks...
Proper way to test battery is to remove from car and use load tester at bench. Checking voltage of installed battery doesn't tell much.
Good luck.
Summary: all the problems were related to the driver's side door sensor thinking that the driver's door was not fully closed.
(The rear driver's side door still doesn't lock with the central locking, but that's because the solenoid/actuator is dead I think.... unrelated.)
Here's a post with more details on those problems...
https://mbworld.org/forums/e-class-w...-sensor-s.html
Thanks!
