Outside Mirror
Old Mar 27, 2010 | 01:32 PM
richpilot35's Avatar
1997 E-300D
Outside Mirror
Can anyone tell me the steps to take to replace the driver's side outside mirror or point me to a diagram, etc?
1997 E-300D
Old Mar 27, 2010 | 02:18 PM
raymond g-'s Avatar
99 E320
if i may suggest, try using the SEARCH function for this forum. posted in
a number of variations and descriptions, including video and photos. use
search terms 'remove outside mirror' or some such
Old Mar 27, 2010 | 03:15 PM
1997 E-300D
Thanks for the heads up!
Old Mar 27, 2010 | 04:41 PM
nelbur's Avatar
1997 E300D
You don't say why you want to replace it. Just so you know, if the problem is that it has gone floppy, there is an easy fix.
Old Mar 27, 2010 | 04:52 PM
1997 E-300D
Thanks for the reply. The auto dim feature and the heated feature are both out.
Old Apr 6, 2010 | 02:43 PM
nelbur's Avatar
1997 E300D
Rich, I have just finished replacing the self dimming glass on the drivers side mirror on my '97 E300D. The glass contains the self dimming stuff and the heating element. It connects electrically using a 5 pin connector. I can't say that your problems would be solved if you replaced the glass alone, but I do not see anything else in the mirror works, relating to the dimming or heating functions. I bought the glass from www.thepartsbin.com for $220. It looks just like the original, except that the part numbers had been eliminated using what must have been a soldering iron. Not sure I understand why they were eliminated.
To answer your original question, there are three screws holding the mirror onto the car. You would also have to unhook the spring, and disconnect the electrical wiring.
If you should want to open up the mirror, use steps 1 & 2 of the following link. This is a DIY I put together after the spring attachment on my passenger side broke. I also used the FIX on my drivers side today as it was in the process of breaking.
https://mbworld.org/forums/e-class-w...-w210-fix.html
Hope this is of some help to you.
Old Apr 6, 2010 | 03:06 PM
1997 E-300D
Nelbur, thanks for the tip. I will have to get the glass from your source and install it. I know others have this problem and your tips go a long way to solve how to do the repair.
Old Apr 6, 2010 | 07:38 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Do it before the gel leaks out - it eats paint.
Old May 8, 2010 | 04:10 PM
5pointswagon's Avatar
1999,1995 e320 wagon
richpilot35,
I just had your same issue. Found a mirror at Carguts in SC. They have one more in stock. Give them a try $190bucks with shipping for the entire mirror.
Nelbur gonna try your floppy mirror solution on passenger mirror thanks for the tip.
