Motul Unigel for coolant in a W210?
I can get my hands on Motul inugel, is it okay to use it for my merc?
If you just drain the radiator and expansion tank you get about 8 liters or ~2 gals hence my recommendation especially if the cooling system is being serviced regularly (ie flush every 3 yrs). Topping off with a little water will still put the OP in the 45:55 to 55:45 acceptable range.
I should check with autohausaz to see if they do ship internationally or i'll just have to suck it up and buy it locally.
I can get the Motul Inugel for $40/gallon which is a lot cheaper then the MB coolant, that's why i was asking about the Motul.
Another alternative is Zerex G05. Many consider it a suitable replacement for the OEM coolant but I have no personal knowledge about that.
Good luck.
http://bevo.mercedes-benz.com/bevoli...0&suchbegriff=
Now, i'm pretty sure i can get the castrol and the caltex brands here. I just want to be sure that these brands won't hurt the car.
note: may, not will. but mercedes has done research on this and has special additives designed to protect their engines optimally. MB-coolant would not be the first choice on another car brand though..
