Need help identifying part on OM606
Old May 27, 2010 | 10:17 PM
EdzBenz's Avatar
W210 W140
Fellas,
I believe I'm getting an oil leak from this part of my engine. I'm having difficulty identifying what part of the engine this is. The part in mention is a cylindrical looking metal piece, facing the passenger side of the car, and is located right above the water pump. Any ideas or help? I'd really appreciate it. Thanks,
Attached Thumbnails Need help identifying part on OM606-dscf0643.jpg   Need help identifying part on OM606-dscf0642.jpg   Need help identifying part on OM606-dscf0641.jpg
Old May 28, 2010 | 09:03 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
No idea but great pictures. Looks like some kind of bleed valve/petcock affair.
Old May 28, 2010 | 10:36 AM
saintz's Avatar
GL450
Are you sure that's leaking and it's not the valve cover above it dripping onto it? Valve covers on Benz engines are prone to leaking. I have no idea what that part is, though.
Old May 29, 2010 | 04:51 AM
Lancelot's Avatar
'01 W210 E320 CDI
I believe that part is a heating element-plug. This was an option. You can connect a 120VAC (in the US) or 230VAC (in Europe) powercord to it to keep the engine luke-warm during harsh winters. Keeping the coolant warm will prevent the Diesel fuel from flaking and ensure a problem-free cold start.
I was under the impression this element was screwed into the engine block but this seems to be in the cylinder head. It is on top of the waterpump though so it sticks right in coolant. I don't think it's oil leaking from there unless it also passes through an oil-channel?!
Old Jun 2, 2010 | 07:29 AM
megott's Avatar
W210 E300D 1996
Hi!
First of all, sorry for my poor english, this is a chain tensioner.
Old Jun 2, 2010 | 12:27 PM
EdzBenz's Avatar
W210 W140
Fellas,
I really appreciate the responses. After some research and other responses, I believe it is the timing chain tensioner. It would make sense because this tensioner has oil pass over it and sometimes leaks. Thanks again,
Old Jun 26, 2014 | 08:53 AM
nowboarder's Avatar
2009 C300 sport
I need some info
I did my oil change and air filter, then I reset the service code B. I am getting a engine warning lite on the dash. I went in and found that I have a code 606 and i need to know what that means. Can anyone help? The car is running great, it has never had any problems.
Old Jun 26, 2014 | 11:14 AM
CHolmes's Avatar
2000 E320
I had a 87 TDT and when I first got the car it had an oil leak, it progressively got worse until I was putting considerable oil through it. One day I was trying to find the leak and discovered it was coming from this exact same part. I tightened it up, washed her off and no more leak. Someone said at the time it was an inspection hole for timing chain but not sure of that. Anyway tighten it up.
