Spark plug tools needed
Old Jul 31, 2010 | 05:14 PM
Javys21's Avatar
01 E320
I want to do the plugs next weekend, can anyone help me out with a list of tools that I might need.
Thank you
Old Jul 31, 2010 | 05:29 PM
Wess's Avatar
2000 E 430
PM Ohlord, I believe he has a special tool for that.
Old Jul 31, 2010 | 05:46 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
You'll need a 3/8" drive ratchet, a 2-3" (? or longer) extension, a 5/8" spark plug socket, a T30 torx bit socket and boot removal tool (Hazet 2771 or equivalent). If you don't have a torque wrench, you can tighten the plugs to seated plus 15 degrees. 15 degrees is equal to 3 hours on the clock face (ie 12 o'clock to 3 o'clock). This is BOSCH approved method.
To get air cleaner out of the way, you need a slotted blade screw driver or appropriate size socket for hose clamp. Rest are just clips.
Did I forget anything?
Old Jul 31, 2010 | 07:48 PM
ohlord's Avatar
It's a T27
that is needed for the coils.
Also a thin walled 16mm spark socket is easier.
a u joint swivel comes in handy
place some rags in the ecu/duo valve area(it likes to hide tools and bits dropped in there
17mm special spark boot tool ........................You really don't want to try the job without it no matter whom you get it from.
Diy procedure on www.benzworld.org w210 forum
ngk 7090 plugs or bosch 7422
don't get suckered into multi tip plugs the m112 and m113 engines hate them.
Take your time
do it on a cold engine with plenty of light and in the shade of a cool tree
Old Jul 31, 2010 | 08:56 PM
RichardM98's Avatar
T30 on my '98 but maybe it changed. 16mm spark plug sockets are very hard to find. Snap-on doesn't even make one. 5/8" works fine.
No problem with multi-tip plugs here. I doubt BOSCH would recommend them if there were any serious problems. But I doubt there is any big advantage either.
+1 on rags and u-joint.
Old Sep 12, 2010 | 06:56 PM
UK-C200's Avatar
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
Gents - getting ready to try this on my SLK, and damned if I can put my hands on that Hazlet boot puller tool. I've got an old pair of KD Tools spark plug boot pliers I used on less sophisticated engines - anyone tried something like this?
Also, anyone know the torque spec's for the plugs?
Old Sep 12, 2010 | 08:55 PM
ohlord's Avatar
28Newt meters
plug
8nm the coil torx
Pliers are a hassle to use.
If you can't get the boot tool you could wait till I find out how much to ship one to you or in a pinch make your own.
Old Sep 12, 2010 | 11:25 PM
RichardM98's Avatar
You might check a dealer. It's MB Part No. 110-589-01-01-00 Valve Adj. tool. I paid $33.55 at my dealer. Some people have reported success with several different pullers including plier-style. But the wrench is perfect for the job.
Old Sep 14, 2010 | 09:50 AM
Ken J's Avatar
w210 E320
I'm confused. Is the special 17mm spark plug boot tool used to unscrew the boot or to pry it off?
Old Sep 14, 2010 | 10:24 AM
RichardM98's Avatar
Actually it's just an open end 17mm wrench with an offset in the handle. There is a ridge near the end of the metal spark plug boot. The 'tool' is used to leverage against the cylinder head and that ridge and pry the boot off. They are a press fit not screwed on.
The boots can be pretty tight after 100K or so and the spark plug wires can get damaged.
Old Sep 15, 2010 | 12:30 PM
Palermo Len's Avatar
1999 Mercedes E320 Wagon & 1927 Bugatti Kit Car
Do yourself a big favor and buy the tool from Ohlord and save yourself a lot of probs. as I did.
Old Sep 15, 2010 | 04:26 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
The tool all are referring to is an offset box wrench that can had purchased from any tool center even sears. The handle is offset. Save your shipping money and get it local to you following RichardM98's post above.
