Need advise on buying new Headlights
. From what I read here, many suggested to buy ones made from Germany but hard to find thru eBay. Below is a link that has HID already installed in it and on its ad states from Germany but also the most expensive one out there. Just confused cuz they range from $120 to $300 plus. Any help is appreciated.http://cgi.ebay.ca/USA-96-97-98-99-M...item1c18dabcb6
For that matter Depo was never the oem maker of the headlights.
You see the light it is putting out in the picture? That is less than what you will get in real life if you buy them. 8000k
Check how much a real quality Xenon bulb d2s or d2r and a good set of ballasts cost subtract the total from those cheap depo units and figure out what quality it totals.
If you must install them find the cheapest set of depo brand
they are all suspect quality and follow the retro fit diy with quality projectors.
2 Under 5 dollar resistors will prevent lamp malfunction warnings.
The guy that wrote their ad must be smoking crack to claim it costs 200 bucks alone for that feature.
Lastly read their refund policy.............Zip,nada,none $340 OUT THE DOOR AND INTO THEIR POCkETS
Luke, did you get yours off ebay?
Do you guys suggest if I go thru ebay, buy the lowest priced ones since they are all probably made by the same manufacturer?
I was wondering if they are such thing as able to convert to d2s bulbs for the H7, hmmm?? thanks again.
--Reggie
To each his own but if you enjoy driving at night on dark roads I'd beg to differ that the light output is not bad.It's worse than that.
Why not start by polishing the lenses you can make them look new for under 20 bucks.
For the HID though, can I install a 50 to 55 watt HID kit or stick with the 35 watt? thanks....
http://cgi.ebay.com/ebaymotors/00-02...Q5fAccessories
