rough idle on cold start and some moke
is sounds like a glow plug i'ts not heating up but i don't get no glowplug indicator when the car is running like it should if a glowplug is bad , is it possible that the glowplug does warm up but not heat up enough , or could it be an injector problem? or what else can anyone sugest ? please any idea is respected and appriciated.
01-17 E61-226 thanks for your help
02-06 228
03-29 224
04-28 230
05-08 232
06-31 233
07-02 234
08-06 454
241
E FF
an other thing is that i pulled out two of the glow plugs and made contact to the engine and turnd them on to heat up, i saw that they only heat up at the tip of it about 3/8 on an inch ,is that haw they should work or are they supposed to heat up all the way to the metalic part which is thicker?
these codes that i showed you are a bit old since i had the EC light staying on and ran the test , you are right i have low refrigirant , so the codes were taken i think before this problem started , but i will pull them out again and see if they show different. just if it would make a difference as well this problem started right after i used the diesel KLEEN product to clean the injectors , i did use some extra of it more then normal in fact but on the bottle it said i could use extra if i wanted faster results.
i'm sorry for writing so much. and thank you
now i'm hoping it is a bad ECT rather then anything else . also note that i don't get good fuel economy anymore , i'm only getting about 24-25 mpg in average mix highway and city , which is not good at all compared to what others are reporting and to what i knew about these engines . maybe this will tell you something more on the problem i'm haveing .
(1 16) (12 4.3)
(2 08) (20 0.0)
(3 26) (21 00)
(4 27) (22 00)
(5 19) (23 00)
(6 41) (24 11.4)
(7 03) (40 60 )
(8 15) (41 19)
(9 00) (42 00)
(10 0.8) (43- 112)
(11 1.8)
Just to make sure i ran the test the right way ! this is how i did it , i lowered the temperature settings to low on auto and by pressing and holding the rest button i was able to collect the values from 1 to 43 i not see the error sign E this time , could it be becouse i changed the CC unit , the first one had a blury screen is it posible that this one has not been able to collect the correct date yet even though it has been several days , even though the first one was taken from another car several months back . however any halp at all i appriciate , thanks again to Plutoe.
i'm in connecticut (north east usa ) and it gets cold here at night but in warmer days it runs better .
Thank you Plutoe.
