Brake light problems...
Recently one of my brake lights bit the dust so I bought a new bulb out it in and unfortunetly it still didnt worked switched the socket and bulb still doesnt work so i was wondering if any has had this problem and fixed it or if anyone had any advice on how to fix it before i take it to the dealership...
battery is connected to the brake switch,
brake switch is connected to the tail light circuit base plate,
circuit plate is connected to the bulb light socket/holder,
bulb light holder is connected to the bulb
you work your way backwards.
you've determined the bulb is not working.
you now check for continuity between bulb and the socket/holder.
then you check for continuity between socket and base plate (which is where the majority of the problems are outside of burnt out bulb).
you can then check to see if power is getting to base plate with D/VOM meter.
usually, the problems are confined within the above....
but occastionally, you will find the open circuit occuring upstream to the
brake light switch.....rarely battery
I'm also presuming when you say brake light, it means brake light....and not
rear running light, reverse, or turn signal light circuit. usually a bulb light problem
is something we can help walk you through rather than having you ending up
at the dealer (yikes)
You are probably forgetting the louver on the transmission tunnel. It's black plastic and has a round fastener you need to turn to remove it.
when the brake is depressed, correct?
probably asking the obvious, but did you
- purchase a dual filament bulb (do the part # match the old bulb...or the functioning bulb on the left side) ?
- purchase the correct dual filament bulb (not 180º opposing pins but should be more like 120º) ?
a modicum of electrical skills may live nearby and assist. hate to have you
bring this into the dealer and take a hit on something so simple
Find any good auto electric shop to test the circuit.
Dealer is going to charge you an arm and a leg.
Or get a multimeter for five bucks and learn how to use it
We have members in Tampa. Somebody help him pleasse
