96 E320 READINESS PROB....
Catalyst Monitor INC
O2 Sensor Mon INC
O2 Heater Mon INC
Ive read on these pages that the Cat Mon wont reset unless it reads the rear O2 sensor. Never have I had a code for O2 sensors, nor do I know the last time they were changed if ever.
Im dying to get this tagged, so I can shake it down.
HELP!
Of course, that assumes there are no issues that would cause a code.
Replace the old tired ones gain back the lost mpg and ready the I/M monitors.
How long have you been driving it since the repair? And did you erase the sec air code or let it clear on its own?
(Except on new cars that are exempt or required by the state to have the dealer fix emissions problem under new car warranty.)
Especially on older cars. You should pass with no problem.
Be sure you are warmed up before the test,don't do it on a cold engine.
Thanks especially to OhLord for his many posts here and on BenzWorld.org on Drive Cycles, IM Readiness and other useful stuff.
In order to smog test, all IM Readiness monitors must now be set.
Ref.
§ 3340.42.2. Test Methods and Standards for the*On–Board Diagnostic inspection*
C.Starting on or after January 1, 2013, OBD*equipped vehicles shall fail the OBD inspection if any*one of the following conditions occurs as applicable to the*vehicle:*
(9) The vehicle’s OBD system reports incomplete*readiness monitor(s) as specified below:*
(B) Gasoline-powered vehicles model-years 2000*and newer with any incomplete monitors, excluding the*evaporative system monitor;*
(Implementation date was set for March 9, 2015)
At least it helps to know the changing rules.
