What kind of Shock should i have to use? BILSTEIN vs SACHS vs MONROE
Old Mar 12, 2012 | 08:23 AM
W210E430HUN's Avatar
W210 E430
Exclamation What kind of Shock should i have to use? BILSTEIN vs SACHS vs MONROE
What kind of Shock should i have to use? BILSTEIN vs SACHS vs MONROE.
I had a car accident, and the rear left Shock are died.
I have to replace the rear 2 Shock with a new one.
For better performance what kind of Shock i have to use?
I want to be Stiffer the ride,more Sporty.
Thank u for helpin.
Old Mar 12, 2012 | 12:48 PM
Fabio D's Avatar
210 55
Koni sport yellow's externally adjustable (replace all 4)
Fabio Daniel
Old Mar 12, 2012 | 01:16 PM
ohlord's Avatar
BILSTEIN
B362154 fr
B362155 re
Firmer ride,still tolerable on the street.
you would not like a single setting(soft to firm) on the yellows unless you take your car to track days at the local track.
Performance/handling comes from so much more than simply changing shock absorbers.
Old Mar 12, 2012 | 07:08 PM
Fabio D's Avatar
210 55
Koni yellows adjustable, are adjustable in 7 positions you can get a pretty soft ride or equal to the OEM ones
Fabio Daniel
Old Mar 12, 2012 | 07:43 PM
grane's Avatar
GLK350, SL63 AMG
Fabio Daniel
Another diddly bit to worry about.
Just get Bilsteins and drive. Don't worry, be happy.
Old Mar 12, 2012 | 08:45 PM
ohlord's Avatar
The softest setting on
yellows is firmer than any HD made. They are performance shocks made for modified suspensions. Lowered,stiffer sway bars,performance springs,tires,etc.
Why ruin a nice ride. And pay 4 times the amount to do it?
Old Mar 12, 2012 | 09:43 PM
raymond g-'s Avatar
99 E320
i bought new Koni yellow body with only 3 settings (not 7) the soft was like
MB OEM ride, the middle was slightly firmer, and #3 was firmest but not as
firm as I'd like.
i then bought the Bilstein HD and it, with its single setting, was noticeably
firmer, yet reasonably compliant, than the firmest Koni.
i sold the Konis to a forum member. very happy with the Bilstein HDs with
1.25" drop on Eibacht progressive wound springs.
Old Mar 13, 2012 | 12:59 PM
Fabio D's Avatar
210 55
I paid 70$ p/u and i'm pretty happy with koni's
Fabio Daniel
Old Mar 13, 2012 | 01:10 PM
ohlord's Avatar
You must have bought
used.
Stiffness of ride does not come from shocks. Shocks dampen.
Op wants stiffer spring rate i.e. lowered springs higher rate.Or cut coil and bigger sway bar. Performance.
Old Mar 13, 2012 | 08:12 PM
Fabio D's Avatar
210 55
Bought them new in a sealed box with all hadrware, included the white nuts to adjuste all package are new 1 year ago
Fabio Daniel
Old Mar 13, 2012 | 08:39 PM
Fabio D's Avatar
210 55
Trust me man. i have the invoice in hand, brand new 75$p/u
We have here a customer e55 with bilstein hd's (ride confort is exelent) and i have the koni's in my car, the 4 position is prety exactly the same as the factory amg/bilstein shocks. the 1st position is like an e320 (a little harder cause the sway bars) and the top position is like a 3.8rs cup :S. Just a very good price for the quality and give you the posibility to play with the car a little if you have some special track day or long travel
Fabio Daniel
Old Mar 13, 2012 | 10:07 PM
raymond g-'s Avatar
99 E320
fabio - can you check invoice and post part numbers for me? i may want to
try those out, especially if #4 is like Bilstein HD. sometimes i with the HDs
had a bit more dampening in them.
Old Mar 13, 2012 | 10:56 PM
Fabio D's Avatar
210 55
Sure Ray, here is the Part #
Front: 8041 1317Sport (Externally adjustable)
Rear: 8041 1318Sport (Externally adjustable)
Front: 26 1602Sport (Internally adjustable)
Rear: 26 1603Sport (Internally adjustables)
* Internally adjustables: "you need to remove it from the car, full compress and turn it 1/4 turn by turn to adjust the settings" like some bilsteins
I have the Externally adustables ones. You can review the Koni website and you would see the adjustable procedure for the 2 models, here is the link for the 99 W210's
http://www.koni-na.com/cat_search.cf...=30&submit.y=9
Check the yellows (Sport). The FSD kit is not adjustable and not suitable for lowered cars like the euro spec E55 (I sent an e-mail and koni people confirm this)
Hope that help
Fabio Daniel
Old Mar 14, 2012 | 02:29 PM
raymond g-'s Avatar
99 E320
thanks, Fabio! i cross checked the part numbers and then searched around but
so far, the few specs and photos i've seen actually showing adjustments point
to 3 clicks. i haven't been able to locate and confirm 7 clickers for them yet.
i'll keep checking.
Old Mar 14, 2012 | 07:25 PM
Fabio D's Avatar
210 55
Yeah, i know is not posted in the web page. I have the papers inside the box comming with the package with the adjustment procedure and special tools, it sayd 7 positions in the externally adjustables. i will search for this papers, and confirm to you again
Fabio Daniel
Old Mar 21, 2012 | 07:19 AM
W210 E430
Fabio Daniel
Thx
Old Mar 23, 2012 | 03:21 AM
01BlackE320's Avatar
01 E320
How are the OEM shocks that Autohausaz sells? arr they actually the same as original?
Old Mar 23, 2012 | 10:36 AM
bmroxm5's Avatar
W210 E320
I was looking into these Bilstein Shocks,
BLS B36-2156,
slightly different part number to what ohlord posted above?
I'm currently on this (Kido shocks and springs - not coilovers despite picture) and the ride is pretty shocking, had this setup for 2 years or so, finally blew a rear left shock so want to change to a quality setup but still stay nice and low. Should I change my springs out as well to Eibachs/HRs or do you think the Kido springs with adjustable perches should go alright with the Bilsteins?
Apparently my current spring rates are 8kg/mm and 9kg/mm, F/R, unsure if linear or progressive.
