Proper wheel-fitment
About to buy my first Benz! A E220 Touring from 2000, facelift. Looks quite good but it sure does need to be lowered asap!
Will be buying a set of wheels aswell, but since I haven't got the car yet I'll ask so the right size will be ordered...
This is what I want! (Sorry for the use of this photo, I'll remove it if neccesary)
What kind of offset would you think this one's got?
or for a nice ride and still performance and look 17's in above sizes
235/45/17 and 265/40/17 within 1 rev per mile front and rear,and your speedo will remain accurate.
The picture you display is not so much a matter of offset or tire size as it is lowering springs and that is a whole nuther kettle of worms.
I've been thinking about buying a 50/40mm lowering spring set? Any opinions on that? Too high/low?
Yea, that 17 inch thought ain't dumb. Looks good with some decent 17 wheels with the correct amount of lowering.... Plus the wheels might get lighter so the car won't loose any power/performance.
H/R or eibachs w210 kit and play around with pads to fine tune.
Camber eccentrics front and K-mac camber bushings for the rear.
Might consider going for a set that lowers 40/40 then, is that easier on the car?
Holy f*ck, didn't know there were such a project to make the W210 driveable when dropped to the ground...
Not entirely convinced on the wheels yet, here's a pic:
Anyone tried these on a wagon? Ü
Is this the normal running temperature for this engine(220CDI) or should I swap to a new thermostat?
H&R spring set from TireRack.com about 250$
KMac rear adjustable eccentrics for camber adjustment check price on Ebay. Otherwise inner edge of tire is gone in 8K miles or less
Bilstein Sport shocks, made shorter for dropped suspension, available from TireRack.com
all wagons in post 99' production came with self leveling rear suspension. Do not readjust rear self leveling as it will adjust itself within a few miles of driving new setup.
With 18s and ET35 you can go 18x8.5 inch wheel in front with up to 245-40-18 tire and no rub. Overall spring drop will be about 1.60 inch front. more than that and you might encounter rub issues. No fender roll is needed.
Use either 265 or 275-35-18 on rear on an 18x9.5 inch wide wheel or up to 265-35-18 on 8.5 inch wide rear wheel. If wheels are 18x8 inch all around and not staggered then use same size front and rear and go 235-40-18 all around.
Do not forget 4 wheel alignment after set up is installed and driven 20-50 miles for settling of new springs.
As a foot note to my above post you are buying only the front Bilstein Sport shocks and keeping the original self leveling set up entirely intact
I'm hell bent on the 19's as the bulky wagon body just requires me to. I've seen a wagon runing on 20s around town and I wonder how they got away wi it because the same reasons you mentioned before. My tire dealer assured me (buy back warranty) that with 30s and 35s tires It would keep my warning lights off. I do not want to mess with the rear suspension.Is there a way of manually or electronically controlling the ride height?
Have you published more pics of your avatar? Love to see more of the white wagon.
Thanks again.
