Something is wrong.....
Old Nov 12, 2012 | 12:27 AM
zheka's Avatar
2001 E320
Exclamation Something is wrong.....
So I was driving on the highway for about 40 minutes, and got off the exit, came to a full stop, and the car died as I came to a full stop. So I started it back on, and it made a grinding noise, and died again. (By now I could smell some kind of burned smell)I turned the radio off, AC off, lights, everything off, started back on again, started fine. Yay, I was happy!! Turned the headlights back on, radio, AC, and it died again, with the same grinding noise.
So now every time I turn the AC on, it makes a grinding noise, and kills the engine right away. Takes about a second or so for the A/C to shut off the engine.
My first thing was the A/C compressor. I am not a mechanic, so is that possible? Can be other things? Any help would be helpful.
**UPDATE: YouTube Video
Old Nov 12, 2012 | 07:29 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
It sounds possibly like a seized AC compressor.
Old Nov 12, 2012 | 10:40 AM
TMAllison's Avatar
09' E320
If your AC comp is that fried, the EC light ought to be lit up permanently telling you there is a fault in the system.
If your Alt went out, the battery light on the dash should be lit up.
Old Nov 12, 2012 | 08:18 PM
zheka's Avatar
2001 E320
**Added the video to the post
Old Nov 12, 2012 | 08:53 PM
zheka's Avatar
2001 E320
No lights came on
Old Nov 13, 2012 | 07:44 AM
Hirnbeiss's Avatar
Judging from the video it's the AC compressor. It is seized up, and the smoke is from your v-belt running alcross the non turning pulley.
Old Nov 13, 2012 | 12:23 PM
TMAllison's Avatar
09' E320
Sparks flying at 22-24 secs.....
Old Nov 13, 2012 | 12:27 PM
zheka's Avatar
2001 E320
I only saw that on the video. I was inside the car, trying not to have the AC running for too long.
Old Nov 14, 2012 | 12:15 PM
Fabio D's Avatar
210 55
Hooolyyy! just replace your AC compressor/dryer filter as soon as possible
Fabio Daniel
Old Nov 14, 2012 | 12:16 PM
zheka's Avatar
2001 E320
I will as soon as I have time. If I don't use my AC at all, it shouldn't really hurt? Or will it?
Old Nov 14, 2012 | 10:49 PM
fabbrisd1's Avatar
A gaggle of MB's
When you go to repair - you will save money by getting your own parts together.
1) Sanden Behr AC compressor - new - $250 - call acpartswarehouse.com to see if they have it
2) Egelhof expansion valve and o-rings $42
3) China Behr drier $22
4) Rein drier-to-condenser hose $36 -
5) Continental belt - $32 3/4/5/6 autohausaz.com
Then find a competant AC shop that will do the right work, including flushing the system, install, evac and refill -in my area about $200 labor all in.
I have found a good numenr of premature compressor failures because the accessory belt tensioner is failing - Litens OE replacement (cheap China tensioners are junk) for $110 - easy DIY or free replacement labor from the aircon guy since the belt is off anyway.
