How well will these wheels fit the E-Class.....
Thanx In Advance...
OZ Opera wheels *Click Here*
I understand OZ has special interchangeable fitments that'll allow their wheels fit the benz's and yes, they look great on the E's - seen them on a few.
The wheel dimensions on the OZ's are standard AMG (i.e. = mine
)But since the offset is variable with different special made spacers/fitmets in the OZ's, make real sure when you get them that they come per below for a good fit (also standard AMG recommendations which is quite aggressive i.e. stretched to the fender limits
):ET35 front
ET31 rear
I personally use 225/40 in the front which are a step down from the standard AMG recommendation but I find steering is slightly more responsive and lighter without having too much error on the speedo but that's just my preference.
Do post pics when you're done.
I've fallen in love with these. Technically based upon the specs given in the auction, would these shoes have any issues fitting the w210?
Thanx In Advance...
18 x 8 $ 450.00 (weights 27 lbs)
18 x 9 $ 500.00 (weights 28.8 lbs)
Both sizes have a 35mm offset.
For a total of $ 1,900.00 price list.
I'd recommend calling tir rack or discount tire, they should be able to give you a pretty good deal on them with out having to go thru the bidding process.
If you want more to see what they look like click here
I don't have offset specs but i can tell you that i run 245/35/19's all around with H&R springs with a coil cut up front and #1 pads and it rubs a little when pulling into driveways or dips where the wheel must be turned. Maybe with Bilstein sport shocks it wouldn't rub but its not that bad.
By the way that pic is at least 2 years old and before springs. The link has the most recent pics that i've taken.
From the pic of the wheels it seems that its a staggered setup. All my wheels are exactly the same and i'm not sure how wide a tire you can put on the rear but i don't think you would have trouble with those.
If I remember correctly, the stock height of the pre-98 W210 (mic's and mine) actually sit higher than the 99+ (yGator's), so it may be little different when fitted on Mic's car.
Hey Gator - nice ride, sorry to pinch your photo.
About the ride height....
If its higher than that he's driving an ML
! That looks different to the "standard" 99+ I've seen around and very much like my car before I lowered it - may be difference between Euro and US specs
):ET35 front
ET31 rear
18X8 et31 front
18X9 et35 rear
i think they will fit just watch your tire size...i have 18x8 et35 on the front w/245-40-18 and they rub....get 235-40-18 or smaller.
I got the same inside rubbing with 18X8 et35 using Nitto 555 tires which have a 'broad' shoulder design. I switched back to Dunlop 9000 to eliminate the rub. It is still very close inside - no room.
so it'll be even closer on stock cars.
