W210 E55 exhaust to e240 2.6 v6
Old Dec 6, 2013 | 02:30 AM
tohir27's Avatar
W210 E240,W211 E280, W210 E200
I have installed original e55 exhaust try to make sound better but i've'nt got enough deep sound as on e55 I know engine not 5.5cc but must have some good effect any suggestions or I need to change some thing else need help
Old Dec 6, 2013 | 10:57 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Exhaust note is highly dependent on the volume of air passing thru the system. You just don't have enough and an exhaust system made for a larger volume isn't helping. You could try a 'glass pack' muffler if it's legal in your area and they are still made. Essentially a straight pipe with some fiberglass around the circumference to deaden the sound a little. But beware that the loss of the designed back pressure could cause engine problems since MB's weren't designed to be 'hot-rodded'.
Old Dec 6, 2013 | 01:18 PM
boltonblue's Avatar
15 AMG S63 4-matic coupe
The easier way to think of it is a tuned horn.
Adding the bell of a tuba to a trumpet will only have a marginal effect and not necessarily the one you want.
Old Dec 6, 2013 | 04:25 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Yeah its never going to sound like an e55 no matter what you do, unless you do a engine swap. Basically in an E240 its like putting a muffler on a civic and expecting it to sound like a supra...just not gonna happen.
Old Dec 7, 2013 | 06:44 AM
matt72's Avatar
c124 124.051
the e55 is quite refined ,not too noisy compared to the amg's of today. i think some owners are fitting x pipes and removing cats,there lots of threads about it. Maybe just use the back box from amg and x pipe on original exhaust and cat removed.
Old Dec 7, 2013 | 03:02 PM
tohir27's Avatar
Cat I already removed I have installed back box from amg e55 but haven't tried x pipe is it really helps?
Old Dec 7, 2013 | 03:27 PM
matt72's Avatar
c124 124.051
sorry i could not tell you,on you tube there are videos,of 320 s with x pipes and various exhausts,its personal taste as well,i drive a diesel and am happy not hearing it
Old Dec 8, 2013 | 08:26 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
There are many differences other than the displacement, firing order, compression rate , and # of valves; V8s have a very unique sound because of the two banks expelling gases simultaneously.
I've seen 320s with an AMG muffler , but there is nothing much you can do about the raspy note.
Cheers.
Old Dec 9, 2013 | 06:36 AM
siopaolover's Avatar
1998 E320
remove the resonator and run straight pipes to your exhaust
