Installing a Turn Signal Switch 1999 E320
Old 12-11-2015, 09:54 PM
Flyboy82's Avatar
95 SL320
I'm attempting to install a New Turn Signal Switch in a 1999 E320, the problem is I cannot find the Airbag Bolts so I can take out the Airbag, I'm using a T30 Torx T Handle, but I just can't find the bolts when I stick it in there. Is there a trick to this, Thanks for any help.
Old 12-12-2015, 01:46 AM
E42AMG???'s Avatar
E420
Are you positive it's a t30? Did you remove all the covers?
Old 12-12-2015, 02:45 AM
Flyboy82's Avatar
95 SL320
It's a T30 alright.
Old 12-12-2015, 07:14 AM
vinceC's Avatar
2014 ML350 4Matic
The bolts are deep in holes at the back of the steering wheel. You need a very long torx bit (3" or so).
Old 12-12-2015, 08:10 AM
Flyboy82's Avatar
95 SL320
My T30 is about 7 inches long, its long enough.
Old 12-12-2015, 05:01 PM
vinceC's Avatar
2014 ML350 4Matic
This is a photo of a 100mm T-30 tore bit engaged in the head of the bolt.
Old 12-13-2015, 03:12 AM
Flyboy82's Avatar
95 SL320
Well, I was finally able to get the airbag out and change the turn signal switch, but found out that did not solve the problem of the turn signal and wipers NOT working. I checked all the fuses in the car and they were alright, so now I'm leaning towards maybe a wiring issue or relay if there is one. Thanks for any help.
Old 12-14-2015, 12:11 PM
Plutoe's Avatar
Received 1,048 Likes on 970 Posts
1999 E300TD
Check the front SAM for the wiper relays!!
Old 12-14-2015, 12:29 PM
Flyboy82's Avatar
95 SL320
I found the problem..It was fuse #3 in the fuse box under the hood.
Quick Reply: Installing a Turn Signal Switch 1999 E320
