18x9 front fitting wheels, needs help!
thanks
The fronts I just put on are 18x8 ET31. That is the AMG setup. You might have problems with rubbing because of the offset and extra inch width. You might need spacers. Check with Whitney about this.
"The clearance from stut housing to the inside of the wheel will be 17mm LESS
The outside edge of the wheel will EXTEND an extra 9mm"
If your E320 has 16X7.5 et41 it will be:
"The clearance from stut housing to the inside of the wheel will be 13mm LESS
The outside edge of the wheel will EXTEND an extra 25mm"
That is not going to fit.
Thanks E-Klasses. I just PM Whiney about this. I'll tried to see if it will fit when my bolts gets here. If it tured out to be a non-fit condition. Hopefully someone on this forum or locally will have (4) 18x8 the same type of wheel that to exchange with, then have to go with the staggered setup. I guess the only bad things is no tire rotations if that's the case.
Don't do it! Per Kev's calcuations, spacers will make things worst!
I finally got my bolts yesterday and got them wheels mounted. It looks pretty sharp. I couldn't believe it actually stll had few mm clearance in the front fender area, no rubbing at all. But I have agree 18x9 is kind big for 235/40/18 tires, the rim still had rooms left for wider tire. You can actually tell it sticks out a little in the front fender area. I wish I did bought 18x8s So I could use bigger wider tires. well, I guess is too late now unless I'll trade with some body else with the front set. But the upside is I can rotate tires now. I'll post some pictures later when is sunny outside. thanks.
Get on the ground with the car on the ground and look at all the suspension bit. I went from 18X8 et31 to 18X8 et35 using a Nitto 555 and it touched completely all the time. I had to use a Dunlop 9000 on the front and there is no more room on the inside.
Also, if your suspension is not stiff, the suspension may rub when the suspension bottoms out.
Also, if your suspension is not stiff, the tire may rub when the suspension bottoms out.
