AC Issues
Here are the numbers:
The EC light is NOT on.
The AC Clutch will not engage.
The Low Pressure reading while running with ac on is 110 psi.
The High Pressure reading while running with ac on is 150 psi.
The only fault code is E 1419.
Here are the readings with car running in 84 degree heat:
1 100
2 84
3 107
4 107
5 103
6 181
7 07
8 91
9 30
10 4.5
11 2.8
12 4.2
Does anyone have an idea where to start troubleshooting?
I have a 2000 E320 with approx 125K miles.
The error codes were:
B 1234 Sun Sensor
B 1235 Emissions Sensor
B 1419 Electromagnetic Clutch
Drove car for 30 to 50 miles with AC on max., but it keeps blowing warm air and codes have not reappeared.
One day later I noted the sensor readings as follows:
01 = 84
02 = 89
03 = 87
04 = 85
05 = 85
06 = 181
07 = 08
08 = 102
Are these reading within range, specifically #5, #6, and #7?
I'm hoping a safety feature or something in the AC system just shut off the electromagnetic clutch/compressor and it's not the AC compressor.
I've read online to check the voltage going to the electromagnetic clutch, I've also read online to test electromagnetic clutch with a direct 12 volt.
Can the electromagnetic clutch be replace by itself, or does the entire AC compressor need to be replaced?
Any assistance is greatly appreciated.
Thanks,
Art
The sensor data/values I just obtained are:
01 = 78
02 = 69
03 = 85
04 = 84
05 = 84
06 = 150
07 = 06
08 = 82
09 = 31
10 = 1.5
11 = 3.9
12 = 4.3
20 = 3.2
21 = 32
22 = 00
23 = 32
24 = 11.6
40 = 164
41 = 85
42 = 40
43 = 136
Is there other data which I need to obtain, if so, can you assist with procedures for obtaining this data?
Thanks again for any assistance......
Art
Follow the comments advise.
Early morning, engine cold:
01 = 67
02 = 66
03 = 73
04 = 71
05 = 71
06 = 80
07 = 5
08 = 69
09 = 27
Mid-day, engine cold:
01 = 121
02 = 91
03 = 123
04 = 120
05 = 105
06 = 157
07 = 9
08 = 107
09 = 27
Mid-day, engine running:
01 = 107
02 = 82
03 = 105
04 = 103
05 = 102
06 = 182
07 = 8
08 = 94
09 = 32
I also checked the low-side & high side at 90 degree temp:
Static Pressure, engine off - low side over 120, high side 115
Engine on, AC off - low side 103, high side 115
Engine on, AC on - low side 105, 125 high side
The AC clutch engages, and disengages when the EC is pressed.
Does this mean the AC compressor is bad, or maybe a valve on the compressor?
Trying to familiarize myself with how the AC works......thanks,
Art
AC clutch on and compressor turning, car interior is hot and the climatronic is set to about 70F.
If you read low side 105 and high 125 psi, the compressor is kaput.
Working compressor should pump in high 200's or even 300's
Is there a way to test to see whether its the compressor control valve, or the compressor itself?
Thanks again,
Art
