98 E430 brake upgrade
Old Dec 1, 2021 | 08:12 PM
MBkid30's Avatar
1998 MB E430
Hello. Does anyone know if there is a bolt on brake upgrade for these cars. The brakes are terrible under sized and the solid rear rotors are horrendous as far as squealing goes.
thanks. The car has 18” wheels.
Old Dec 3, 2021 | 06:45 AM
MBkid30's Avatar
1998 MB E430
Thanks, but that doesn’t answer the question. And I’m a tech at a dealer so there is nothing wrong with them other than they are undersized for the job they were designed to do!
Old Dec 4, 2021 | 12:37 PM
illest's Avatar
w210 AMG or S213
w203 C55 calipers will bolt on the front (will fit under 17inch rims), there are some others that will fit like CL500 and maybe E500 w211 etc. Search will help a lot.
I have w220 s65 calipers on the rear of mine with slk55 rotors. This post has more info
Old Dec 4, 2021 | 03:39 PM
MBkid30's Avatar
1998 MB E430
Perfect! Thanks. I’ll have to do some digging and get some parts together.
do you use the same rotors with the calipers? Is the spacing OK for the caliper to go over the rotor?
Old Dec 4, 2021 | 11:07 PM
illest's Avatar
w210 AMG or S213
You have to use different rotors. The rotors you use will depend on the calipers you choose, when I had cl500 calipers I had to space them a little with washers to get the rotor to align properly,.
If you read all the threads below hopefully you will have all the answers you need.
https://mbworld.org/forums/e-class-w...e-upgrade.html
https://mbworld.org/forums/e-class-w...-how-much.html
https://mbworld.org/forums/e-class-w...w210-e320.html
https://mbworld.org/forums/e-class-w...installed.html
Old Dec 4, 2021 | 11:51 PM
MBkid30's Avatar
1998 MB E430
thank you. Much appreciated.
Old Dec 6, 2021 | 06:59 AM
RKP Waco's Avatar
1999 E300
02-09 CLK 500, front and rear are a direct bolt on and the fronts are Brembos.
