Driver side mirror repair/replacement.
I unfortunately today backed out of my driveway and smashed my driver side mirror and it fell off. The mirror is not cracked and the chassis is in fine condition. I’m wondering if it’s possible to repair this and put it all back together or if it’s unable to be repaired and would need to buy a replacement part? Is jt straight forward to reinstall if I bought the part? Do I need to recode the wiring or anything or would it be plug and play sort of thing. Considering the replacement part is $140 i’d prefer do it myself then pay someone.
Below are some photos of the after math.
Here is the only replacement part from Australia I can find.
https://www.ebay.com.au/itm/374741261414?hash=item574051dc66:g:n6EAAOSwHL1kew4 j&amdata=enc%3AAQAIAAAA8LkodI8jQpubIvYZp%2BGYeDcCo ybllI%2B8R%2Bg6mYSFpqcde2OriliAG6SkP5rbtvzYbYgRtFt atq2sSQKi7xt3E1bZOLdJ2gFiGphVz13SvaH2s8ht4iiu6CdMf FPBRgPhT%2FmP76aj1e3m72DBNykBPK3d7w66kd7xbPqWe0p9A 0DtQbZ0dg3uekqyS2vDComx1fhg1UrqH9v2dOE%2B3Q4hWxkxm fYg%2FIPbrDcX%2FBcqwcXBWkHYNzDmHXEZky%2FM44T3fHb64 yxyOzgypveNOFeA6P6CQOGiAOAtwVwgEXUoeXCrI4J4%2BBh2h A%2BzWiiHUZnCgw%3D%3D%7Ctkp%3ABFBM6OKd2OFi
Yeah, finding the right-hand drive stuff is hard as only few country have this unique setup ( you guys down there, England, South Africa, Japan just to name a few. I think there few more somewhere in Africa). Maybe someone can chime in to see if you can use the right side mirror from left-hand drive cars.
Thanks for your reply. So you have to remove the door panel to replace the mirror? Just did a little googling and it seems it’s attached with screws and the tutorial didn’t remove the door panel. Does this seem right? In regards to the programming do you need to go to a service shop to get them to use their machine (i.e machine used to reset airbag fault warnings etc)
Hopefully someone here has done this and can shes some light.
I appreciate your response 🙂
No, you do not need to remove the door panel. Sorry for the confusion.
But I'm not expert on MB electrical or sensors, so I hope someone can chime in soon.
Nonetheless the mechanism is toast. Repairing is all but impossible as parts are under high tension due to the spring and the metal framing surrounding the motor is pot metal if I remember correctly. Given that degree of damage I believe the structural integrity has been compromised beyond mending.
The w210 models came with 2 distinct, non-interchangeable designs so be sure you purchase the correct one for your year...which appears to be a post facelift 2000-2002 model.
I am not familiar with nuances such as heated, auto dimming etc which a donor mirror may need to be compatible with (for your car).
Look through the threads in this STICKY....navigate to "Mirror, outside..."
https://www.benzworld.org/threads/0-...order.1720154/
It's a tad bid tricky to swap out. Yes, there are only 3 fasteners but to get to them the sequence accessing them must be in a specific order. You are also fighting a STRONG spring...one which makes you utter naughty words if your fingers gets caught. If you don't see the instructions in the STICKY, come back here and I'll see if I can walk you through it (from memory). It's been a few years.
Tutorial says to push a flat head screwdriver down here (between casing and metal frame) that will release the clip (clip shown in picture one)
From aging memory, these were the tools I used:
wooden stakes I had laying around from yard work, approx .5" x 1.5" x 15"
couple of short bar clamps like these
using the combination of the above, I carefully and slowly pried apart the mirror assembly against spring tension.....while at the same time, inserting the stakes to incrementally widening up the opening in stages. At a certain point, I may have even inserted a short chunk of a 2x4 wood. the trick is in opening it just wide enough so that you can gauge access to the fasteners. keep in mind that while you hold up all this octopus assembly you will also need to be able to insert the fasteners along with the tool needed to turn them.
The photo below is tricky and it was taken of my 1999 mirror which is different than yours. HOWEVER I used your photos and tried to edit the critical parts and pasted them onto my own photo to give you a rough idea what they will look like within your mirror housing.
This next part is a worded description of your locking mechanism. Understanding this simple part may make it easier for you to 'pick the lock' and jiggle it free and allow the plastic housing to slide out and removed.
The 2 RED ARROWS point to the ski ramps 1) of the mirror motorized assembly and 2) of the mirror cover. As the plastic cover is slid over the motorized unit/frame, the ski ramps help locate and engage to mating parts. At the critical moment the metal spring clip.....and the plastic part of the ski ramp come to the end of the sliding ramps.....GREEN LINE....and the parallel surfaces lock into place.
So to undo this you simply need to press the spring retaining clip enough to jiggle the plastic housing while pulling it outwards. You said it still won't come apart. No big deal. It's usually stiction, accumulated crud from weathering, gunk on the rubber gasket..... but firm and gentle jiggling should do the trick. Just be sure that the metal spring retaining clip is depressed enough (I'm guessing .5") so that the 2 parallel surfaces clear each other. PRESSING ACTION should be downwards...and in the direction towards the reflective mirror.
oh, going back to this photo you posted, yes. You would be sliding a flat blade in that area you circled far enough to engage the spring clip and then, swinging the screwdriver in the direction of the plastic housing. That should push the spring clip in the opposite direction....sufficient to clear the matching contact surface on the plastic housing. It may not be easy to do this with only two hands and the mirror moving around. This may be where I used the ratcheting bar clamps hold it rigidly against a workbench or something.
I feel like the more words I type may confuse things so we'll just work on this incrementally and progressively. if you get stuck we'll just work from there.
All the above have enough tips to get you started though. It's a bit of a Rubik's Cube but once you've done this, you will be able to finesse this the rest of your life and laugh at the trauma in hindsight
Another thought after posting the above yesterday: when you insert a thin flat blade tool into the innards, if the shaft is thin enough try ROTATING the screwdriver as this will turn the wider portion of the screwdriver bit and further press the spring clip/tab inwards. That might just provide the needed clearance for it to clear the plastic retaining surface on the inside of the plastic mirror shell...kind of like what a skeleton key does to manipulate the locking mechanism
The earliest I'll have access to that mirror will be around Nov 11 (another family member has it now). But from memory, I'm now second guessing the spot you should be inserting the screwdriver. Here is the photo you provided but I'm squinting and thinking perhaps it may be here (green).
Once you pry apart and look carefully with a headlamp (or have someone shine a bright light) you should be able to see the glint of the spring clip anyway. I don't think there is anything else that reflective inside. Either way, look for reflective glint through both crevices.
Another reason I'm thinking it may be in accessible via the green zone is because when I study your other photo, that sharp almost 90º bend is almost 10-15mm so to press on that portion would need to be at least 10-15mm away from the inside surface of the plastic housing. That, in itself, seems to exceed that opening in the red arrow/circle in your archived photo. That's why I'm thinking the green zone above.
So I should correct my doctored photo above.... from this....to this.....
The blade of your screwdriver should be on the NARROW portion of the metal tab marked by the green arrow in the second photo (immediately above). That red curve with the peak is the profile of the inside surface of the mirror cover. You job, should you wish to accept it, is to push the metal tab so it clears that red peak....which is the latching portion of the plastic housing. Once you get them apart, you'll smack your forehead and think DUH ... is that all !?
insert your flat blade in the recess identified by the green curved arrow. then, push the screwdriver handle to the left which should pivot the silver tab to the right....which should allow the silver tab to clear the plastic housing latch and allow you to pull it off.
e.g. https://www.ebay.com/sch/i.html?_nkw...mirror+gasket+
