E-Class (W211) 2003-2009
August 05 Recalls
Old Aug 8, 2005 | 07:22 PM
konigstiger's Avatar
'71 Pinto
Arrow August 05 Recalls
August 05 campaigns (A service recall is one that gets done on the next visit).
(1) Recall Campaign # 2005070007
Model Year 2004 - Models 211 & 230
Inspect SBC Hydraulic Unit, replace as directed
(15979 vehicles affected)
SBC brake system may prematurely shift to the hydraulic back up mode due to the loosening of the ground wire harness connection over time, or due to premature failure of the hydraulic pump. Dealers will install a bracket and replace the ground wire, and if required, replace the hydraulic pump and suction hose.
All vehicles subject to last years SBC recall, both open and closed will be campaigned under this years SBC campaigns.
211:
A470365 to A475255, A470992 to A508719, A461620, A457431 to A511132, A457447 to A511135, A457425 to A510794, X119124 to X123272, X119111 to X123267, A465748, A457426 to A510952, X119113 to X123268
X119110 to X123264
230:
F070784 to F077518, F070783 to F077529, F070797 to F077483
(2) Service Campaign # 2005060008
Model Year 2003-2005 – Models 211 & 219 (2006)
Programming battery control module
(152949 vehicles affected)
Implausible or illogical messages can appear in the instrument cluster which will result in certain electrical consumers being shut down. This is caused by the battery control unit erroneously evaluating the battery charge level as good when the actual charge level may be insufficient.
211:
A086421 to A601974, A200763 to A749546, A200763 to A749546, A178744 to A756955, A273079, A679184, A708977 to A756979, A056822, A461620, A014562 to A418838, A042945 to A756973, A400339 to A607461, A136286 to A756990, X108074 to X180280, X108399 to X181693, X177825 to X181700, A465748 to A577987
A606738, A702004 to A720233, A427785, A710773 to A756916, A407369 to A450439, A307691 to A732056 A307815 to A387669, A715663 to A756602, X108182 to X178465, X108624 to X181673, X174229 to X181683
219:
A000205 to A016000, A007370 to A015997
(3) Service Campaign # 2005070017
Model Year 2002-2005 – Models 211 & 230
Inspect alternator, replace regulator if necessary
(14923 vehicles affected)
The alternator regulator may fail to prevent voltage values ranging beyond the specified tolerance limits. As a result, the battery may be insufficiently recharged and the convenience systems may be shut off due to a resulting under voltage condition. The voltage drop is accompanied by a corresponding message display at the instrument cluster.
211:
A461620, A457431 to A511132, A457447 to A511135, A457425 to A510794, X119124 to X123272, X119111 to X123267, A457426 to A510952, X119113 to X123268, X119110 to X123264
230:
F070783 to F077529
Old Aug 8, 2005 | 07:46 PM
W211 Ryda's Avatar
2004 E320
Just received my Recall Campaign # 2005070007 today.
Old Aug 9, 2005 | 09:15 AM
calum's Avatar
2005 W169 A150
thanks for the excellent data, konigstiger.
I've just received my recall letter here in the UK, for an SBC issue, and yet my chassis no is not anywhere near those listed. Odd.
(I am near, although just outside, the battery control module recall list, but haven't had a letter for that one).
Old Aug 9, 2005 | 11:17 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Yeah thanks!
Old Aug 9, 2005 | 11:23 AM
BudC's Avatar
2011 E550, 2013 GLK
Phoenix Motors called me yesterday and told me all three recalls apply to my 3/04 build E320 and that they came out 8/2. Phoenix Motors haven't done two of them yet so I'm going to wait a while for someone else to be the guinea pig
Old Aug 9, 2005 | 04:13 PM
alewifebp's Avatar
2014 BMW 550i
Good to finally see the BCM recall issued. That had been announced months ago.
Old Aug 9, 2005 | 04:18 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Based on my experience with their service dept.. that would be a very good idea.
Old Aug 9, 2005 | 04:28 PM
fubar's Avatar
'06 E350
[(2) Service Campaign # 2005060008
(152949 vehicles affected)]
Is this the one that causes the A/C to turn off when it's hot? It happened to me again today (2nd time).
fubar
Old Aug 9, 2005 | 04:34 PM
BudC's Avatar
2011 E550, 2013 GLK
I've had great (albeit expensive) service on both my cars at PMC. I use Robert Wolf as a Service Advisor. I'll admit that I'm reluctant to have the SBC recall performed until they've done some. I was surprised that the MBUSA letter said it took 4 hours. Now THAT does make me nervous.
Old Aug 11, 2005 | 03:25 PM
baldmike73's Avatar
whats this code
whats the code for replace tansmission at 7k on the clock.
my 05 e500 has been in the shop for 6 weeks now since the tranny was backordered to germany. a host of other issues too. what a pain. been at the dealer since mid June. so depressing. have only had the car for 7 months. bad control unit on the tranny and metal shavings found in the transmission. I so miss my car!
Old Aug 11, 2005 | 07:18 PM
allen_7's Avatar
2016 E350, 2013 C300 4MATIC, 2004.5 C230SS
Took my 04/E500 in yesterday for the moonroof issue and the service advisor told me about the recalls. They need (Penske MB in W. Covina) 2 days to do everything since they are missing parts for the recalls.
Old Aug 11, 2005 | 08:42 PM
CE750's Avatar
Makes me glad that mine was done at the factory.. hate to have these rookie CDI mechs tearing into my car. I I had the GateWay flash done last week while in there for my "service reminder rest" issue.. apparently this "Gateway" is the Central Bus of the car... so I wonder what was changed?
Old Aug 11, 2005 | 09:13 PM
BudC's Avatar
2011 E550, 2013 GLK
The SBC recall adds a bracket to keep the plug for the SBC ground wire from coming out. According to the recall letter, the change takes 4 hours. They must have to do some serious cable rework.
The recall for the voltage regulator tests it and if it's bad, I understand they replace the entire alternator.
The battery recall doesn't require a part.
So the only two parts I know about are the bracket (and perhaps the ground cable) along with the possibility of an alternator.
Old Aug 17, 2005 | 07:40 PM
NuBenz's Avatar
02 996 C2 Cabrio
Count me in, boys!
My saga of pain with the SBC system never seems to end. My first '03 E500 was a lemon due to the SBC brakes having multiple pump failures (leaking).
Now, in my "new" E500 4MATIC, the SBC has already been reprogrammed. Then, I just received the letter regarding the latest SBC recall requiring the installation of a special bracket to the system. I just spoke with my advisor and guess what? My car falls into the class that requires replacement of the SBC pump!
I already had 2 SBC pump replacements in my '03... grrreat. The second pump I had to wait 9 weeks for prior to installation due to the unavailability of the pumps that were being remanufactured in Germany.
While it's in, it's getting a software flash and the alternator recall that the advisor just found out about. I do not know if the replacement parts are even in stock right now.
I'm speechless.
Old Aug 17, 2005 | 07:51 PM
BudC's Avatar
2011 E550, 2013 GLK
This Info was released to dealers August 6th. Sounds like your advisor isn't keeping up to date. I'm waiting on my recalls until they do a few. There's no rush and I want to make sure that when they do the SBC cable change, they know what they're doing. I'd wait a while if I were you. When they did the first SBC recall, people rushed to dealers before they knew how to bleed the brakes. Consequently, some people had some problems.
MBUSA has been sitting on this stuff for quite a while so it's not a life and death situation.
Old Aug 17, 2005 | 09:58 PM
CE750's Avatar
though you would think it was buy the tone of some of the members here..
Old Aug 20, 2005 | 12:58 PM
NuBenz's Avatar
02 996 C2 Cabrio
I'd wait a while if I were you. MBUSA has been sitting on this stuff for quite a while so it's not a life and death situation.
BudC, this is a recap of my disappointing experience with SBC: SBC failure
My comments are towards the bottom of the thread.
In reference to my current car, the brakes were working fine except for an occasional pressure relief type squeaking sound that I would hear every once in a while. It sounded like a reservoir purging itself.
On this latest visit, the dealer replaced the SBC pump and did the cable upgrade. The advisor also mentioned changing out the alternator, but I don't have the invoice in front of me right now.
I have reasonable confidence in my dealer's ability to work on cars. The disconnect, I believe, starts at MBUSA and then filters on down to the dealers. There's definitely a communication issue, and my advisor's lack of knowledge of the alternator TSB is simply par for the course.
Knock wood
Cheers,
Old Aug 20, 2005 | 05:37 PM
mr.louie's Avatar
Mercedes 03 E500
Smile Service advisor says there are no recalls for my car
My service advisor claims that my car has no current recalls. He punched in the serial number and checked on the computer. Is that how they check for any potential recalls?
Old Aug 20, 2005 | 05:46 PM
BudC's Avatar
2011 E550, 2013 GLK
Check your Vin number against the first post on this thread. These are three outstanding recall/service campaigns.
If your Vin number doesn't match any of the ones listed, you should be OK. If it does, you should print off the first post and show it to your SA.
Old Aug 20, 2005 | 10:58 PM
SGEM's Avatar
2024 C300W4
Just wondering what you folks are doing. Are you calling your SA as stated by BudC or waiting for the recall letter to come in? My VIN number appears in the original post but have not received anything yet.
Old Aug 20, 2005 | 11:33 PM
BudC's Avatar
2011 E550, 2013 GLK
The only recall campaign is for the SBC. It's called a safety campaign and you'll get a letter about it. I just got mine. The letter says you should take your car in sometime in the next 60 days and that it will take four hours to do the work
The other two are service campaigns and are done the next time you bring your car in for service.
Old Aug 23, 2005 | 11:23 AM
saffrontiger's Avatar
W211 2005 CDI, X166 2013 350 BT, 997.1 2008 C4S
refresh
