E-Class (W211) 2003-2009
Old Jun 9, 2015, 04:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: General Overview
Print Wikipost
W211 Recalls!
Old Nov 12, 2007 | 12:46 AM
  #76
noyu's Avatar
17 E43, 18 GLE400
Applicable to all 211 E-Class & 219 CLS models; also solves any cracking/creaking noises heard from the steering rack area when steering vehicle at low speeds or when the vehicle is stationary. Washers are installed and nuts replaced/torqued.
Can you guys be a little more specific about P-B-46.40/53?
I think I have the same problem but the dealer said the 2 lower balljoint was worn and making the noise and were replaced under warranty.
However the problem / noise still exist and I am in Toronto, Canada so I need something a little more specific so I can show it to my dealer and have them check that again!
Thank you very much in advance!
Old Nov 12, 2007 | 10:03 AM
  #77
konigstiger's Avatar
'71 Pinto
Originally Posted by noyu
Can you guys be a little more specific about P-B-46.40/53? I need something a little more specific so I can show it to my dealer and have them check that again!
Check your email for a copy.
Old Nov 12, 2007 | 12:12 PM
  #78
noyu's Avatar
17 E43, 18 GLE400
Thanks got it!
You are the man! I really appreciated it!
Old Nov 12, 2007 | 08:36 PM
  #79
DESAL's Avatar
GLC SUV 350e4 Verde Silver Metallic
Just in time - thanks
Thanks for posting - Putting it to the test. I took delivery last week of my 2005 from the dealer and just emailed the salesman to see what has or has not been done. It will be very interesting to see what comes back. The dealership already failed the "certified check list" Were a some mirror things but the big one - the stop light bar on the truck was not working when they delivered the car. Have had no comments from the "delivery survey".
Old Dec 18, 2007 | 03:15 PM
  #80
'71 Pinto
P-B-42.46/84 NOV07 SBC or battery fault message displayed in instrument cluster
211.026/065/070/076/265/276 VIN range A040665 up to A589444
211.082/083/282/283 VIN range X097815 up to X161341
This may be the result of damage to the engine or interior compartment wiring harness in the area of the auxiliary battery. The interior compartment wiring harness contains the supply line for the auxiliary battery relay. The engine and/or interior compartment wiring harness will be replaced.
P-B-07.16/80 NOV07 - 211.022/026 fuel loss at the pressure regulator valve (PRV) and/or poor engine running characteristics (shakes, knocks, surges, changes to limp mode, poor output, poor fuel economy, combustion noise) this may be caused by a malfunction at the PRV due to improper installation. The entire rail will be replaced; PRVs cannot be replaced individually due to possible imprecise installation processes in the workshop.
Old Dec 18, 2007 | 03:28 PM
  #81
glojo's Avatar
E-class E300e Estate, Sprinter (stretched limo)
Thanks very much indeed for the excellent information. Is this just a TSB or a more serious recall?
Thanks again
Regards
John from a very cold, dark, Torquay
Old Dec 18, 2007 | 03:40 PM
  #82
'71 Pinto
Originally Posted by glojo
Thanks very much indeed for the excellent information. Is this just a TSB or a more serious recall? Thanks again Regards John from a very cold, dark, Torquay
Hi John,
DTB, not a recall. Just added another DTB relative to diesels.
Old Dec 18, 2007 | 03:50 PM
  #83
glojo's Avatar
Thanks very much
Regards
John
Old Dec 27, 2007 | 03:38 PM
  #84
SteveBC16's Avatar
Veteran: Army
2019 E450 4Matic, 2018 E400 Coupe
Service Campaign 2007-100004
I just received a letter from my dealer regarding this recall. They mentioned that my 2006 4Matic may require the replacement of the transfer case. First, they have to remove the rear engine cover and check the serial number of the transfer case. If the serial number of the transfer case falls within a certain range, it will have to be replaced.
Anyone else receive this notice and/or have any info on this recall?
Thanks and Best Wishes for the Holiday Season.
Steve
Old Dec 27, 2007 | 05:39 PM
  #85
'71 Pinto
Steve
https://mbworld.org/forums/showpost....9&postcount=56
Old Dec 28, 2007 | 06:20 PM
  #86
'71 Pinto
Service Campaign 2007100004 DEC07 approximately 8,327 vehicles affected: 2005 and 2006 211 and 220 4MATIC; transfer case serial number range between 115925 and 137342 – optimized transfer cases will reduce vibrations when cornering or when parking. Have your dealer check VMI to see if your vehicle is included.
Steve, PM your email address if you want a copy.
Old Dec 29, 2007 | 01:10 AM
  #87
Esleeper's Avatar
CLS
Wow,
I don't even own a W211 yet but what a great help konigstiger is!
Tell me Mr Konigstiger with your infinite wisdom when looking for a 2003-2005 E320 or E500 with 30-50k miles which is a better car overall? They seem to be priced about the same. What I really want is a E320 Sport or E500 for the airmatic.
Thanks in advance.
Sleep
Old Dec 29, 2007 | 06:29 PM
  #88
'71 Pinto
“Mr. Konigstiger”? An aristocrat, anyway I would suggest you start a new thread with your question to get accurate hands-on feedback from those who own the model(s) of interest.
Old Dec 31, 2007 | 06:42 PM
  #89
E320joy's Avatar
2015 S550
My 03 E320 just starting making a "thud" sound at low speeds on the passenger side front when I go over imperfections in the road. I am glad to see this possible solution. I'm due for my service in a few weeks and will have my dealer check it out then. Thanks for the post and the information!!!! It was driving me crazy
Old Jan 1, 2008 | 02:39 PM
  #90
'71 Pinto
You may need to replace the upper ball joint as per DTB P-B-33.15/22.
Old Jan 3, 2008 | 10:16 PM
  #91
Benz-O-Rama's Avatar
Just had this happen to my car. Replace passenger ball joint, thrust arm and thrust arm bearing.
Bargained my dealer down to 650.00 including parts.
https://mbworld.org/forums/showthrea...ghlight=thrust
Old Jan 6, 2008 | 03:19 PM
  #92
hecdog's Avatar
2014 E350 Estate Wagon 4Matic
Hey Konigstiger, regarding this:
Service Campaign 2007010004 MAR07 – Models 211, 219, 221, 230, X164 (M273 engine, 550) Check intake manifold and replace if necessary; Install updated engine control module software. Running characteristics can be improved with the installation of a modified intake manifold. Additionally, updated engine control software will also be installed. Approximately 11,352 vehicles affected.
Manifold production date up to and including SEPT 30 2005, replace manifold.
Manifold production date between (and including) OCT 1 2005 and FEB 28 2006, install engine control module software.
I just took in my w211 2004 wagon (produced oct 2003) in for service and submitted the campaign number to the service rep. He didn't look up the number, but instead looked up the list of recalls, etc that come up with the vin number and said there weren't any open service bulletins. This one service campaign (2007010004 MAR07) was not on the list. Does that mean that my car doesn't need it? or is there some place they can check to see if it applies to my car? Sometimes my car's exhaust seems rough and I wonder if this is the problem...
Old Jan 6, 2008 | 06:45 PM
  #93
'71 Pinto
Originally Posted by hecdog
I just took in my w211 2004 wagon (produced oct 2003) in for service and submitted the campaign number to the service rep. He didn't look up the number, but instead looked up the list of recalls, etc that come up with the vin number and said there weren't any open service bulletins. This one service campaign (2007010004 MAR07) was not on the list. Does that mean that my car doesn't need it? Sometimes my car's exhaust seems rough and I wonder if this is the problem...
This campaign is only applicable to the 550 engine therefore, your vehicle is not included. To date I am not aware of any DTBs for intermittent rough exhaust.
Old Jan 7, 2008 | 04:44 AM
  #94
hecdog's Avatar
Thanks! I'm blind. I missed the "550" in the DTB.
I think it's the EGR valve. It was problematic before so I'll have them check that...
Old Jan 11, 2008 | 09:15 PM
  #95
E320joy's Avatar
2015 S550
Thankfully I purchased the extended warranty! I have an appointment for this coming Tuesday. I'll post when I find out exactly what the problem is. Thanks for the information.
Old Jan 19, 2008 | 11:50 PM
  #96
'71 Pinto
Service Campaign 2008010001 JAN08 - MY04 and 05 models 203, 209, 211, 215, 230 the inner funnel material of the catalytic converter on affected vehicles may warp causing noise. Dealers will check the production date on the catalytic converter and replace if found to be between 2/1/04 and 4/30/04. Approximately 6597 vehicles affected.
This applies even if you are out of warranty! If you want a copy that includes instruction on how to check the date PM your email address.
Old Jan 20, 2008 | 01:08 AM
  #97
lasvegas99's Avatar
E500
Service Campaign at MB Authorized service?
Read through and didn't see if the work must be done by a MB dealer or could it be done at any MB authorized service center? Got my car from a dealership that is authorized in MB, BMW etc.. I can call and check too but thought it could be good for the thread. Always great info.
konigstiger for president 2008
Old Jan 20, 2008 | 08:15 PM
  #98
'71 Pinto
First note Recall and Service Campaigns do not expire in other words MBUSA pays and there is no out of pocket for the owner. Having said this, a MB dealer should be the first choice. However, if one would rather have an independent perform the work make sure they do not charge for the inspection if they find the catalytic converters are not within production range for replacement. Furthermore although MBUSA authorized, each shop may have their own policy on performing recalls and/or service campaigns therefore, it would best to call to confirm.
Old Feb 6, 2008 | 06:52 PM
  #99
pinebaron's Avatar
07 E320 Bluetec
Bluetec Campaign ???
My SA called me yesterday to come in for a couple of parts replacement. He said it was some exhaust flow thing or something, a new Campaign. I took it in today, they spent about 45 minutes while I waited. I asked the SA again; this time he said it was the two intake housings. Oh..OK. I was in a hurry and left.
At home I looked under the hood and engine cover. I could not tell what they replaced; I mean the car has always been spotless under the hood.
I would love to know if anyone knows about this new Campaign and details.
Old Feb 8, 2008 | 07:05 PM
  #100
pinebaron's Avatar
07 E320 Bluetec
Is it possible it was Service Campaign 2007010004 MAR07?
When I took a closer look in bright sunshine today, I found the intake manifold clamp screws obviously had been removed and reinstalled; they had socket marks on the edges; they may have replaced the intake manifold.
You have already rated this thread Rating: Thread Rating: 7 votes, 4.86 average.
