Washed, waxed and a 10 minute mod (Clear corners)
Got my clear corners in today and had them installed in 10 minutes flat.
Here's how they turned out.
Received 1,753 Likes
2016 E350 Sport
Gorgeous!
Originally Posted by jocon63
Much better than the Orange markers.. Where did u get them and approx cost ?
Thanks for the compliments...
They were an eBay special.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Seller shipped them the day after I paid from California and I had them in Maryland in 3 days. Couldn't have asked for more.
Originally Posted by kaggz1227
hows the install process?
Couldn't be easier. Just use a small flat head screwdriver to pop out the old ones. Start by inserting the screwdriver at the rear most end of the light, and the whole thing pretty much pops out. Then you just pop out the bulb assembly and insert it in the new light. Insert the forward most portion of the new light and then let the rear just click in. Really, a blind man with one hand could do it.
Originally Posted by crb49
Verrry nice. I like your rims also. Mfg?
1 Post
sold - w211 e320, f250, rx7 race car
just an FYI, I had the clear corners from ebay for about month and they would get water in them and fog up. Not sure if they were defective or that's just how they are. I changed to Euro strips shortly thereafter.
I'll keep a look out for that. The hole in the back for the bulb assembly is the only point of entry into the inside of the lamp. On mine, the bulb assembly has a gasket around it where it meets the back of the light and it twists in and locks. So it seals up pretty good. I'll definately keep a look out though. Thanks for the heads up.
1 Post
11 ML350W2 / 17 GLC300
I found the clear corners to have somewhat brittle mounting clips. I have had to reinforce them with a plastic-epoxy and aluminum after they cracked. I have also replaced the bulbs with silvered-amber bulbs to get rid of the yellow cast the clear corners had when the bulbs were not lit.
I left the clear bulbs in instead of using the amber ones that come with the clear corners. So I don't have the problem of yellow showing through when the lights are off. And the clear corners I bought do not have brittle mounting clips. Mine are the same quality as the OEM's I took out. They look, smell, taste, act just the like the OEMs.
Its big and Grey!
To each their own though. . . . . .
2004 E320
Originally Posted by rodE350
what you guys think.....will the clear corner lenses look good on a white E?
Originally Posted by W211 Ryda
IMO…clear corners would look better on a light colored car…especially on white, rather than a dark colored car. I bought a set of clears on Ebay about a year ago and was impressed with the quality, finish, and fitment but sold it a couple of weeks later to a forum member. It was made by Depo, which is a popular manufacturer of clear corners for other makes of cars. Clear corners > stock ambers
2004 E320
why did you sell it? you went to the Euro bumper strips?
Yeah, sold it because I wanted the euro look…a cleaner front. If I didn’t get the euro strips, I would definitely keep the clears.
EHEM!!!!
No posting on my thread unless you're talking about how sick my car looks.
That is all. Carry on.
2004 E320
EHEM!!!!
LMAO! nice sig pic...like it better than your previous one!
